Round Jeep logo on front side??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Round Jeep logo on front side???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Boss is away but Erin is here to STAY with a F.Y.S. SaFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 10-05-2012, 04:01 PM   #1
OJEEPO
How do you remove the little round logo located on the right side and the antenna base on the left? Do I need to remove inner fenders?
OJEEPO is offline   Reply With Quote Quick reply to this message
Unread 10-05-2012, 10:27 PM   #2
kosmos
I have not removed mine - perhaps it comes off like the front JEEP emblem:
[SIZE=2] ** You can sleep in your Jeep but you can't drive your house **[/SIZE]
[SIZE="1"]2012 JK Rubicon in [COLOR="#FF0000"]Flame Red[/COLOR], ACE Rock Sliders, LoD Stubby Stinger front, LoD Stubby rear,Rock-Krawler 3.5" X factor Pro mid-arm, RCV ultimate front axles, Warn PP HP, 37" KM2s on AEV Savegre wheels, 10 Factory rear axles,MC front Fenders, Reid Knuckles,aFe Cold Air[/SIZE]
kosmos is offline   Reply With Quote Quick reply to this message
Unread 10-05-2012, 10:58 PM   #3
maniacal_rick
Bfh?
2012 2Dr JK - Metalcloak - Currie - Prorock - ARB - Poison Spyder - RCV - Synergy - Etc...
maniacal_rick is offline   Reply With Quote Quick reply to this message
Unread 10-06-2012, 07:10 AM   #4
ncb
The TR emblem can be removed using dental floss or fish line. "Floss" it right off.
Antenna-
1. Disconnect and isolate the battery negative cable.
2. Remove the glove box from the instrument panel.
3. Reach through the instrument panel glove box opening to unplug the two antenna coaxial cables in line connector.
4. Unscrew the antenna mast from the antenna body base on the right outer cowl side panel.
5. Using a trim stick, gently pry the edge of the antenna base trim cover to unsnap it from the antenna body base.
6. Remove the three screws that secure the antenna body base to the right outer cowl side panel.
7. From inside the passenger compartment, push the coaxial cable grommet on the antenna body half of the coaxial cable out through the hole in the right inner cowl side panel.
8. From the outside of the vehicle, pull the antenna body base and cable assembly out through the hole in the right outer cowl side panel.
Installation
1. From outside the vehicle, feed the antenna cable and base assembly through the outer cowl side panel and into the inner cowl side panel hole.
2. From inside the passenger compartment, pull the cable and grommet into the hole in the inside cowl side panel until the grommet is fully seated.
3. Install the three screws retaining the antenna body base to right outer cowl side panel. Tighten the screws to 3.3 N·m (30 in. lbs.).
4. Snap on the antenna base trim cover to the antenna body base.
5. Install antenna mast. Tighten to 5 N·m (46 in. lbs.). Ensure that the antenna mast is fully seated on antenna base and that there is no gap between the mast and base.
6. Reach through the glove box opening and connect the two antenna coaxial cables in line connector.
7. Install the glove box to the instrument panel.
8. Connect the battery negative cable.
ncb is offline   Reply With Quote Quick reply to this message
Unread 10-06-2012, 05:44 PM   #5
smittycm
I used a heat gun to warm the TR sticker up and then peeled it off with my fingers.
2012 JKU Sport S, RK 2.5" Max Travel, Bilstein Shocks, AEV Savegre Wheels, GY Duratrac 315/70R17
smittycm is offline   Reply With Quote Quick reply to this message
