Rough Country vs. Teraflex 2.5 BB help? - JeepForum.com
post #1 of 6 Old 09-26-2013, 10:14 PM Thread Starter
Mfrancis
2014 JK Wrangler
I am trying to decide between these two BBs. Anyone running one or the other, or has tried both? The RC mentions it is recommended to also get the rear track bar bracket to center the axle. Is this necessary and if so, why only the rear? Will I need a track bar bracket for the TF as well?
http://www.roughcountry.com/jeep-sus...kit-634-7.html
http://www.teraflex.biz/jk-wrangler-...get-boost.html
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #2 of 6 Old 09-26-2013, 10:22 PM
planman
Thanks to all Mod erators
planman's Avatar
The clearance is tighter in the rear between the swaybar, frame, brakelines, and wheels/tires. So, the rear axle really needs to be centered, especially if running aftermarket rear swaybar links.
The tolerances in the front are not as close. It is not a big deal to have the axle a little off center with up to a 2.5" lift.
Between those two, the Teraflex has stronger shock extensions and thicker steel for the trackbar bracket. It is worth the extra $.
planman is offline
post #3 of 6 Old 09-27-2013, 05:13 AM
JTPhoto
JTPhoto's Avatar
X2 TeraFlex ... It comes complete with everything you need. I've installed a few of theses and they are problem free and easily upgradeable.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #4 of 6 Old 09-27-2013, 09:30 AM Thread Starter
Mfrancis
2014 JK Wrangler
Will I need the exhaust spacers with the 2.5 bb?
Mfrancis is offline
post #5 of 6 Old 09-27-2013, 11:04 AM
JTPhoto
JTPhoto's Avatar
A lift is a lift, whether spring or BB it is suggested that 2.5" + in lift to use either an exhaust space, new exhaust Y pipe or Tom Woods driveshaft.. Any of the 3 will give you driveshaft clearance.
^^Jeff^^
JTPhoto is offline
post #6 of 6 Old 09-27-2013, 11:06 AM Thread Starter
Mfrancis
2014 JK Wrangler
Good info, thanks.
Mfrancis is offline
