Rough Country vs Spydertrax 1.5" wheel spacers. - Page 3 - JeepForum.com
View Poll Results: Which wheel spacers???
Spydertrax for $200. 42 54.55%
Rough Country for half the price. 35 45.45%
Voters: 77. You may not vote on this poll
post #31 of 73 Old 01-01-2011, 05:23 PM
Butterbuddha
2010 JK Wrangler
The JK specific tag there just refers to 5X5 bolt pattern of the JK, thats all. As for the spacers I've only had mine a short time with no problems. Its a good idea to check the torque on them when you rotate your tires though. And good luck keeping your ride clean with all that rubber poking out
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #32 of 73 Old 01-01-2011, 05:26 PM
Rafi
2010 JK Wrangler
I have been running the spiertrax for almost a year now and 0 issues.
they are high quality, and worth the cost IMO
Rafi is offline
post #33 of 73 Old 01-01-2011, 06:07 PM
Unknown303
... delete??
Unknown303 is offline
post #34 of 73 Old 01-01-2011, 06:15 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Originally Posted by Unknown303 View Post
Right from here;
http://roughcountry.com/wheel-spacers_1091.html
States that they are hubcentric.
At the time that I wrote that (April 2010) the RC spacers were not hub centric.
They have since changed their design to a hub-centric machining.
If you get a set of used R/C spacers be sure to verify that they are of the new design.
Jim
JLC08JK is offline
post #35 of 73 Old 01-01-2011, 06:20 PM
Unknown303
Originally Posted by JLC08JK View Post
At the time that I wrote that the RC spacers were not hub centric.
Yeah I read further into the thread and saw you mentioned that. I actually have the old design on mine and really have no issue with them at all. I just made damn sure the surfaces were almost polished clean and slowly put the lug nuts on until they seated. Tightened a little more and then rubber mallet time. After that torqued to spec.
post #36 of 73 Old 01-01-2011, 06:44 PM
troyka75
2005 WK
I ended up finding a deal on the spidertrax from 4wheelparts and went with them. So sorry for the firedrill but the more I read through it the more paranoid I got All I keep picturing is my 10 year old son and not wanting to flip jeep as a wheel flew off. I got them for $180 bucks shipping included.
troyka75 is offline
post #37 of 73 Old 01-01-2011, 06:56 PM
Unknown303
Decent price for sure. I figuer eventually I'll probably try out the new Gen RC's or try out some Spidertrax. I find no matter what parts you get it will largely come down to maintenance on them. If you ignore retorquing something your just begging for something bad to happen.
post #38 of 73 Old 01-01-2011, 07:00 PM
Dogzilla
Spidertrax cured a BAD case of DeathWobble for me. I HIGHLY recommend em.
Dogzilla is offline
post #39 of 73 Old 01-01-2011, 07:12 PM
Unknown303
That is not even possible in the realm of physics.
post #40 of 73 Old 01-01-2011, 07:16 PM
Butterbuddha
2010 JK Wrangler
uh whhhaaaa????? Death Wobble is normally loose and/or bent/broken components in your steering??? What does that have to do with wheel spacing???
post #41 of 73 Old 01-01-2011, 07:27 PM
Unknown303
I heard that Spidertrax spacers also cure cancer and aids.
post #42 of 73 Old 01-01-2011, 07:47 PM
JLC08JK
JLC08JK's Avatar
Wheel spacers will change the relation between the tire and the pivot point at the ball joint of the steering (scrub radius) thus having an affect on the overall characteristics of the steering.
I would not be so quick to dismiss the possibility of spacers making an improvement and possibly curing some of the negative aspects of the steering.
Curing death wobble? I doubt it.
Positive improvement? quite possible!
Jim
JLC08JK is offline
post #43 of 73 Old 01-02-2011, 07:25 AM
jdog1065
2010 JK Wrangler
I went with Spidertrax. I got them through their "Outlet" for $79 a pair. They have cosmetic blemishes, but I couldn't find anything wrong with the ones I got, and they have the same warranty as the "regular" ones.
jdog1065 is offline
post #44 of 73 Old 01-02-2011, 08:04 AM
Dogzilla
But....it's what happened! We eliminated every other possible cause....only left the adapter/spacers. When we changed those, the DW went away. Completely. Don't ask me how, but it did.
Dogzilla is offline
post #45 of 73 Old 01-02-2011, 08:08 AM
Dogzilla
Don't be ridiculous! That's the Pentastar that's gonna do that!
Dogzilla is offline
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 12:18 PM
rough country wheel spacers anyone? rballman JK Wrangler Technical Forum 4 03-17-2009 07:11 AM
Rough Country wheel spacers JP4LIFE TJ Wrangler Technical Forum 13 02-27-2009 09:30 AM
4" rough country w/ 2" spacers????? tjwhlr00 TJ Wrangler Technical Forum 17 11-07-2006 10:58 PM
Torque specs for Spydertrax wheel spacers UCTJ TJ Wrangler Technical Forum 8 04-14-2006 11:05 AM
