Rough Country Stock JK Front Bumper Caps - JeepForum.com
post #1 of 11 Old 04-20-2010, 06:21 PM Thread Starter
PlatinumOre
Wasn't able to find any threads about these so heres mine.
I ordered from Rough Country's website.
Heres a link: Jeep Accessories - JK Bumper Caps
I wanted that stubby bumper look but wasn't ready to dip into my other project savings so here is a simple solution that looks pretty good and was an easy install.
Removed the shroud... that got trimmed too. Then eventually thrown away.
You'll put some tape or chalk on the bumper to make your cut line leaving just enough to pin the new caps onto.
Careful cutting the metal had a bend in it, hard on the ol' sawsall.
My cuts weren't perfect had to take another 1/4 of an inch or so off to get them to sit how i wanted them to.
soo...Cut em off, slid the caps onto the remaining bit of bumper on the side drilled some holes and put the plastic pins in.
If you do this make sure you drill through both layers of plastic or the pins wont sit flush and will be a pain in the rear to pull out to fix.
You'll notice the caps are a bit darker than the bumper and flares but i attributed this to fading. Some Armor-all brought the colors real close, the sun will do the rest of the work.
Cant decide if i want the shroud on or off, I'm thinking off. Tell me what you think.(edit: took it off completely)
Pics:
PlatinumOre is offline
post #2 of 11 Old 04-20-2010, 06:46 PM
MattJK09
2009 JK Wrangler
I like it. Looks nicer than my chop job did when I sawzalled mine before I bought the RR stubby.
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline
post #3 of 11 Old 04-20-2010, 06:56 PM
yoda13
Force Wheeler
yoda13's Avatar
I like that...am contemplating what I am going to do with my bumper if anything...this is one of the things I am considering
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #4 of 11 Old 04-20-2010, 07:00 PM Thread Starter
PlatinumOre
yeah im pleased with how they turned out, Any opinion on the shroud?
also, ill add this in the original post too but the caps are a bit darker than the bumper and flares but i attributed this to fading. Some Armor-all brought the colors real close, the sun will do the rest of the work.
post #5 of 11 Old 04-20-2010, 07:12 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
What shroud are you speaking of
The caps look good, they just came out with them in the past month or so
Jim
JLC08JK is offline
post #6 of 11 Old 04-20-2010, 07:16 PM
detonator
2009 JK Wrangler
I vote to leave the shroud off. I have already pulled mine off. You might want to leave it on if you plan on doing any significant mudding and water work. Just thinkin'.
detonator is offline
post #7 of 11 Old 04-20-2010, 07:28 PM Thread Starter
PlatinumOre
@ JLC08JK: the Shroud, under the stock bumper is a plastic piece that just covers the front end bottom.
Yeah Ill just take it off come tomorrow.
With it off it also looks like it sits higher because the shroud hangs a good 2 inches lower.
post #8 of 11 Old 04-20-2010, 08:08 PM
McKBrew
JK Wrangler
If only they had come out with these sooner. Now my bumper is too short for them.
McKBrew is offline
post #9 of 11 Old 04-20-2010, 09:55 PM
yoda13
Force Wheeler
yoda13's Avatar
yeah, take the plastic shroud off...mine has been off for almost a year now...maybe more
forum...
yoda13 is offline
post #10 of 11 Old 04-21-2010, 10:46 AM
09WRANGLER
2009 JK Wrangler
I love it !!! Just ordered as set, I have Ome light coils upfront so can't really put a heavy bumper, I was about to try the bumper chop until I saw those, Nice clean look, should've been that way from factory !!!
Thank you rough country
09 2dr Sahara, OME coil lift w/shocks, F/R Jks trackbar, Solid diff covers F/R, RC disco's, 16" ultrawheel nomad, 33" Duratracs, Body armor rail, Dynomax catback, ...
09WRANGLER is offline
post #11 of 11 Old 04-21-2010, 03:41 PM Thread Starter
PlatinumOre
Bumper caps have now faded and match up with the OE plastic bumper quite well
bumper , caps , mod , rough country , stock
stock bumper end caps kwkouki TJ Wrangler Technical Forum 4 01-01-2010 01:48 AM
Stock bumper end caps? 4Guts Wrangler General Discussion 8 12-19-2009 11:54 PM
New Stock Bumper End Caps d04tj TJ Wrangler Technical Forum 23 09-25-2009 12:05 AM
Rough Country Front Bumper** jgtree Wrangler General Discussion 0 09-16-2008 08:39 AM
anybody pick up the rough country front bumper? alecmcmahon TJ Wrangler Technical Forum 2 09-08-2008 05:34 PM
