Rough Country 2.5" JKU Coils On A 2 Door - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Rough Country 2.5" JKU Coils On A 2 Door
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOld Man Emu WK Lift - Black Friday Special!!The Original 3/8" Ruffstuff Diff Cover!
Unread 09-25-2014, 12:28 PM   #1
AdvanZ33
I bought a set of used RC coils today but they are for a JKU. I've read a lot of threads about installing stock JKU coils on a 2 door but not aftermarket coils. Does anyone have any experience with installing aftermarket JKU coils on a 2 door? I'm assuming it will follow the same geometry as the OEM coils and possibly add ~1" to the advertised lift but I really don't want to lift the Jeep more than 3".
AdvanZ33 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 01:15 PM   #2
ncb
RC coils sag quickly so it might keep your 2 door at 2.5" if you're lucky. The geometry will not remain the same as the OEM coils. The axles will shift and caster will decrease.
ncb is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 02:14 PM   #3
SLADE
Similar question asked in another current thread.
http://www.jeepforum.com/forum/f96/w...coils-2724826/
No it's not uncommon to use 4 door/JKU lift coils in a 2 door/JK. Not all companies offer 2 door/4 door specific coils. If they are labeled as a 2.5" 4 door coil you should expect around 1" additional lift to even 1.5" (varies from company to company) when used on a 2 door and you'll have to build around the actual lift height and not just what the coil is labeled as. You can't skimp on components just because it's called a 2.5" lift coil. If you end up with 3.5"+, you'll have to accommodate 3.5"+. The first couple inches of lift is fairly cheap. Once to crest the 3" mark the $1000 per 1" of lift becomes much more accurate and true.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 07:24 AM   #4
AdvanZ33
Right on, thanks for the responses. After a little more research and measuring, these RC coils (used and sagged) are 1" taller than OEM coils; front and rear. That, along with the higher spring rate, should put me around where I want to be hopefully and I'll buy supporting mods when I confirm the lift height.
2 door vs. 4 door , coil spring , jku , rough country 2.5
