Quantcast Rotated Tires and found something - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Rotated Tires and found something
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-06-2009, 07:15 AM   #1
oaklane
We've taken our 07 JK to the dealers 3 times for the front axle leaking, the last visit being last April and they finally found a piece of metal in there causing it to leak. So that was corrected.
Yesterday we rotated our tires and noticed when we put the front tires on the bolts or what they are attached to, moved slightly making a couple of the holes that the bolts go through not circular. We're assuming this shouldn't be the case.
Now it's going back again this week to make sure that they didn't forget to tighten up something from a year ago. Bad timing, we were planning on driving 800 miles this weekend with it to NY. We don't want to be driving down the highway and have to slam on the brakes and the bolts brake off causing the wheel to fall off?
Update: Just spoke to Dealer and I guess it's normal for it to have a little float in it. Phew!
Thank you in advance for your thoughts/ideas.
It's A Jeep Thing.......,
http://s234.photobucket.com/albums/ee102/oaklane76/My%20Addiction/
oaklane is offline   Reply With Quote
Old 04-06-2009, 09:00 AM   #2
SoCalJK
First time I pushed on the rotors and they moved I also got a shock but I guess it is the way that they are designed on the JK.
2007 Sahara Unlimited
4x4, Auto, Jeep Green, Tow Package, Soft top
With guns, we are citizens, without them we are subjects!
SoCalJK is offline   Reply With Quote
Old 04-06-2009, 09:10 AM   #3
oaklane
So I wasted my weekend being mad that something else is wrong with the axles.
Old 04-06-2009, 10:41 AM   #4
JIMBOX
There's no difference in the JK rotors or wheels
If there's ANY PLAY in the front rotors, then either the other side moves EXACTLY the same-or somethings loose, axle brg/tierod/ball joint/spindle/links
The wheels do not have oblong holes and the HUB, STUD, LUG NUTS, should be TORQUED to at least 95 lbft-no play
If they're steel wheels, they shouldn't have alloy lug nuts and if they're alloy wheels, they shouldn't have steel wheel lug nuts
JIMBO
JIMBOX is offline   Reply With Quote
Old 04-06-2009, 10:49 AM   #5
desertjk
It's good practice to check the torque on the lug nuts before every off road trip.
2007 2 door Rubicon. 3.5" RE lift, 35" Goodyear MTRs, Procomp 8179 15x8 wheels, 4.88 Superior gears and alloy shafts. Shrockworks stubby front bumper, Rockhard rear bumper, JE Reel 1350 driveshafts, Warn Powerplant winch, CB, GPS.
desertjk is offline   Reply With Quote
Old 04-06-2009, 10:58 AM   #6
NYCJohn
2009 JK Wrangler
The tire/rim will clamp the rotors from moving... Don't worry.
NYCJohn is offline   Reply With Quote
Old 04-06-2009, 02:55 PM   #7
oaklane
They took in just to make sure and said it's "normal" what it's doing. Never noticed the other times we rotated the tires.
Glock Forum
