Rollbar speaker screw i should use, phillips doesnt work. - JeepForum.com
post #1 of 8 Old 11-14-2012, 08:43 PM Thread Starter
denny1514
I tried using a phillips to unscrew the rollbar bar speakers but it looks like like i need a special tip. Does anyone know?
thanks in advance
denny1514 is offline
post #2 of 8 Old 11-14-2012, 08:44 PM
maniacal_rick
Torx, T-10 or T-15...cant remember.
2012 2Dr JK - Metalcloak - Currie - Prorock - ARB - Poison Spyder - RCV - Synergy - Etc...
maniacal_rick is offline
post #3 of 8 Old 11-15-2012, 12:26 AM
1222
RIP John
1222's Avatar
If you plan on doing any work on your JK you’re going to need to get a torx bit kit. Any tool supply place carries them.
(2011-2016)
1222 is offline
post #4 of 8 Old 11-15-2012, 02:00 AM
waterboarder
waterboarder's Avatar
Just drill it out.
waterboarder is offline
post #5 of 8 Old 11-15-2012, 03:23 AM
perryhooah
Jeep uses a LOT of Torx head screws... Probably Torx...
2008 UNLIMITED
OIF ('03-'04) & OEF ('07-'08)('12-'13) Veteran
perryhooah is offline
post #6 of 8 Old 11-15-2012, 08:38 AM Thread Starter
denny1514
Do you know where i can get the Torx bits that will fit the JK slots in the trunk area?
thanks
Dennis
post #7 of 8 Old 11-15-2012, 09:48 AM
maniacal_rick
He already told you once.
post #8 of 8 Old 11-15-2012, 02:54 PM
1222
RIP John
1222's Avatar
The ones (speaker screws) on my 2012 are T-15 like maniacal_rick mentioned up above. I would imagine that they are the same for all models.
Just in case you are a bit confused as to what Torx bits are, take a look here. If you buy a set then I suggest getting the ones that require a ratchet to use, that way you’ll be able to apply enough torque to remove the larger stubborn ones. Also but not necessary, try to buy a quality set, for instance craftsman (I have harbor freight Torx bits too). Not using a tight fitting bit that is somewhat rounded can ruin your day.
denny1514, please fill out your profile when you get a chance, it will come in handy when you post in the JK tech section, thanks.
(2011-2016)
1222 is offline
