Rock Krawler High Clearance Front LCA - JeepForum.com
post #1 of 6 Old 12-15-2015, 07:32 PM Thread Starter
Apettenon
Hello!
Has any body used Rock Krawlers Front LCA's and shortened them to adjust castor angle? From my understanding the majority of LCA's are designed to be extended...not shortened.I would prefer to only replace the front LCA's due to ease of install.
The guy at the 4x4 shop scared me poopless when he said a leading cause of death of due to improper castor angle in lifted vehicals.Any help would be grateful.
EDIT: So i guess my questions is... What is the best way to adjust castor using the OEM driveshaft without having to replace both upper and lower CA's??
Apettenon is offline
post #2 of 6 Old 12-15-2015, 07:39 PM
SLADE
If your lifted, you want to lengthen the lower control arms longer than factory length to correct caster, not shorten them.
You want your caster in the 4.5-5 range.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #3 of 6 Old 12-15-2015, 08:00 PM Thread Starter
Apettenon
Im sitting at about 3" of lift with no control arms
post #4 of 6 Old 12-15-2015, 08:08 PM
SLADE
Look into some Synergy or Metalcloak adjustable arms. Synergy has some fixed length arms also if you want simple and cheap. Metalcloak uses Duraflex joints and Synergy has a Dual Durometer bushing that they are using now. Great arms from great companies and people.
Metalcloak
http://www.metalcloak.com/Metalcloak...Kits-s/231.htm
Synergy
http://www.synergymfg.com/Jeep-JK-p-1-c-4055.html
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #5 of 6 Old 12-16-2015, 06:16 AM
motoguy1251
I swapped my Rock Krawler control arms out for Metalcloaks.
motoguy1251 is offline
post #6 of 6 Old 12-17-2015, 05:22 PM
propped1
Originally Posted by Apettenon View Post
Hello!
You need to do a bit more reading. There is no driveshaft adjustment. The Tcase is solid mounted. the axle is kept on a predictable plane. The DS is only a connector. You go up and out, the connection needs to be longer. It is reacting to the length not causing it.
You dont need to replace uppers. Only lowers. And they need to be longer not shorter... also what do you mean you are sitting on 3" of lift with no control arms. That is literally not possible.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
