Rock Hard Skid Plate - JeepForum.com
post #1 of 12 Old 05-14-2009, 03:01 PM Thread Starter
vkaz46
2009 JK Wrangler
Anybody install one of the oil pan transmission catylitic converter skid plates on a Rubicon? The instructions they sent me were kind of generic. It says to remove and discard the forward crossmember. My rubicon does not have a forward crossmember it only has the crossmember that goes under the transmission. I think the instructions are for all versions of the wrangler. Does the x and Sahara have a forward crossmember.
vkaz46 is offline
post #2 of 12 Old 05-14-2009, 03:05 PM
VICTIM_OF_PAIN
VICTIM_OF_PAIN's Avatar
I know this sounds like a silly question. When you bought the skid, did you specify for a JK?
Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.
Current - 2008 Unlimited Wrangler Rubicon. Rock Krawler Stock Mod 2.5" lift, 35x12.50x15 Cooper STT's on Pro-Comp D-Windows, Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, Rugged Ridge E-Disco Skid, and a Skid Row Evap Canister Skid plate.
It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt.
VICTIM_OF_PAIN is offline
post #3 of 12 Old 05-14-2009, 03:18 PM
pixeldzn
I installed one on my 4 door rubi, and definitely had to remove the forward crossmember. It is the one that has a plate in the middle of it right under the front driveshaft.
Maybe yours was previously removed?
pixeldzn is offline
post #4 of 12 Old 05-14-2009, 03:39 PM Thread Starter
vkaz46
2009 JK Wrangler
I haven't ordered it yet I just told them to fax me a copy of the instructions so I could look them over before I ordered one to see what all was involved with the install.
vkaz46 is offline
post #5 of 12 Old 05-14-2009, 03:40 PM
VICTIM_OF_PAIN
I think the other guy has the right answer for you.
post #6 of 12 Old 05-14-2009, 03:48 PM Thread Starter
vkaz46
2009 JK Wrangler
I have a 2 door. I purchased it brand new a couple of months ago so unless the factory forgot to install it I can't see why it wouldn't be there. I would take a picture and post it but I suck with computers and can't figure out how to load them. The only cross member i see under mine is the one that my tranny mounts to and it just seems like a bad idea to remove that one. Not to mention in the picture the back of the skid plate is bolted to the one that is under my jeep. Maybe I am just not figuring it out. I have never worked on jeeps before but I have been a helicopter mechanic for 14 years in the Marine Corps so I don't think it should be that hard to install but when it starts telling me to remove parts that arn't there I get a little nervous.
If you have an e-mail address you could pm to me I could send you a picture and you could tell me if you see it or not.
vkaz46 is offline
post #7 of 12 Old 05-14-2009, 04:02 PM
terrahawk
If you have a manual trans, you won't have that POS.
Speed has never killed anyone - suddenly becoming stationary, that's what gets you!
terrahawk is offline
post #8 of 12 Old 05-14-2009, 04:30 PM
WVUJeeper
Start a photobucket account and then upload your pictures there. Copy the link to the photos here and we can usually fix them.
Edit: I'm too ignorant to answer your real question.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread:
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline
post #9 of 12 Old 05-14-2009, 09:21 PM Thread Starter
vkaz46
2009 JK Wrangler
That is kinda what I was thinking but wasn't 100% sure. I guess I will go ahead and order the thing if someone else here has installed it I know it is possible. Add it to the list. I already got a bumper, winch, front skid plate, and cb to install before next weekend. Thanks for the info Terrahawk
vkaz46 is offline
post #10 of 12 Old 05-14-2009, 09:23 PM Thread Starter
vkaz46
2009 JK Wrangler
Thanks for the advice with the photobucket. What part of WV did you live in? I grew up in Wheeling.
vkaz46 is offline
post #11 of 12 Old 05-15-2009, 02:05 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I think they are referring to the automatic transmission cross member/skid plate.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #12 of 12 Old 05-15-2009, 03:31 PM
terrahawk
I have the skids on the 6 speed, no cross memeber to remove. Should have pointed that out, sorry.
Rancho Rock Gear Oil Pan Skid Plate CreepJeep JK Wrangler Technical Forum 7 02-12-2009 08:35 PM
High Rock front bumber and Warn steering skid plate dgrady72 TJ Wrangler Technical Forum 4 08-01-2008 05:52 PM
Rock Hard license plate relocation bracket DBraceM20 TJ Wrangler Technical Forum 1 03-23-2008 09:32 PM
Clayton Hard-Arm Skid Plate VinoTJ TJ Wrangler Technical Forum 3 07-13-2007 12:19 PM
Rock Hard 4x4 Plate Relocation/ORO Platelight Kit ryobi TJ Wrangler Technical Forum 14 04-24-2007 01:22 PM
