Risk of Front Trackbar Bracket Ripping Off w/ BB - JeepForum.com
post #1 of 36 Old 02-14-2013, 03:20 PM Thread Starter
4wdjeepguy
What is the risk of the front axle side track bar/steering stabilizer mount ripping off while running a BB? Would a 3-4" lift bring the same amount of risk? I've been trying to filter for some responses regarding this topic, but figured that I would just ask.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #2 of 36 Old 02-14-2013, 06:37 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Well, based on what I read, with a BB of up to 2 inches, no problems really noted. When you go up to a 3 or 4 inch lift, then you are into adjustable track bar or brackets to correctly center the axle. The brackets put additional leverage on the factory
bracket and have been known to break the factory weld. The solution seems to install bracket gussets to reinforce the factory mount and also some weld the new adjustment bracket to the factory bracket to ensure stability/strength. Just my 2 cents.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 36 Old 02-15-2013, 02:20 PM
Maertz
2009 JK Wrangler
I personally wouldnt worry about it. I ve been running 4" for quite some time now and had no issues. In extreme offroading it may break, but i wheel mildy and have had no issues. As for recentering the axle with the track bar i would not worry about it Mine is only about an 1/8 off so id need to move it about 1/16 to get it centered...My lift did come with a track bar bracket though that bolted on to raise it slightly.
Maertz is offline
post #4 of 36 Old 02-15-2013, 09:05 PM
RockyClymer
RedRock4Wheeler
The geometry of the front (and rear) would calculate to almost 5/16 in to the driver side in front and 5/16 in to the passanger side in the rear for a total offset of 5/8 in with a 4 inch lift (a crab walk for me). Some may not worry about this, I do...Just my 2 cents. Either proper brackets or adj track bar can correct this.
NRA Life member
post #5 of 36 Old 02-15-2013, 09:16 PM
Spank
2014 JK Wrangler
If you have your SS still positioned in the stock location, you risk tearing the actual shock off just because it's poorly located to begin with, lift or not. I have no idea why Jeep thinks hanging that thing off the bottom of the tie rod is a good idea. I tore mine off on a wheeling trip after I bought my Jeep and it was still stock.
However, like RockyClymer said, the trackbar mount on both axles have always been weak and getting a lift and/or generic relocation mount only shortens the amount of time until the inevitable. Luckily, it's easy to weld it back on and you can always add more metal either before or after it happens to strengthen it up. Just don't take it to the dealership because they'll want to sell you an entirely new axle. A decent welding shop should be able to take care of both in roughly an hour.
Likewise, with the SS, if you do manage to relocate and/or replace it, you don't need to spend crazy money on an aftermarket one. The stock SS is more than adequate.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #6 of 36 Old 02-16-2013, 04:34 AM
wardo
2011 JK Wrangler
The factory track bar bracket is pretty fragile. I check it for cracks whenever I change the oil, just in case.
2011 Flame Red 2dr Wrangler Rubicon, Poison Spyder Evap Skid, Extended Breatherlines, 4' Firefly Antenna, Uniden Pro520xl, Rock Krawler 2.5 Stock Mod Lift, Bilstein 5100's, Rugged Ridge XHD Front Bumper, Warn M8000, Rugged Ridge XHD Snorkel
wardo is offline
post #7 of 36 Old 09-20-2013, 02:06 PM Thread Starter
4wdjeepguy
Any new opinions on this?
post #8 of 36 Old 09-22-2013, 03:55 AM
TRAUMAhead
2010 JK Wrangler
Rare occurrence, I've only read 1 or 2 stories of the bracket being ripped off. I had mine replaced because the track bar holes were wallowed out.
TRAUMAhead is offline
post #9 of 36 Old 09-22-2013, 07:17 AM
Waltjason
2011 JK Wrangler
My bracket ripped off after 2 years and very mild off-roading. Was going about 65 on the highway when it happened. Of course traffic was bad. I sure had to change my drawers after that. Worst experience in the world couldn't use the breaks had to coast it to a stop.
Waltjason is offline
post #10 of 36 Old 09-22-2013, 08:11 AM
brianjw
I've seen instances where the frame side bracket ripped off too.
The factory track bar is soft and weak, so are the bushings. A more solid aftermarket track bar will put more stress on those mounts, and they should be reinforced.
brianjw is offline
post #11 of 36 Old 09-22-2013, 12:12 PM
zjilla
Is that all the axles really move at 4" of lift? Thats very minimal
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #12 of 36 Old 09-22-2013, 03:10 PM
Spank
2014 JK Wrangler
Unless Jeep changes the design of the bracket on the axle in any future application of the JK, no. It'll always be a weak POS and should be taken care of via a quality aftermarket product if you plan on lifting. Same with the SS (the SS itself is fine, but its position is not).
Spank is offline
post #13 of 36 Old 09-22-2013, 06:31 PM Thread Starter
4wdjeepguy
Is that the Artec bracket?
post #14 of 36 Old 09-23-2013, 11:21 AM
TRAUMAhead
2010 JK Wrangler
Yep.
post #15 of 36 Old 09-23-2013, 11:30 AM
JTPhoto
JTPhoto's Avatar
AEV's solution.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
