Ripp Superchargers - Page 6 - JeepForum.com
post #76 of 133 Old 12-05-2010, 06:46 AM
JB7JEEP
2010 JK Wrangler
That's cool, I'm sold as well! Thanks again for all the input and videos.
JB7JEEP is offline
post #77 of 133 Old 12-08-2010, 02:39 PM
TDmaster
2009 JK Wrangler
Originally Posted by JB7JEEP View Post
My other question for you or Ripp or any other member is: has anyone run the stage 2 SC with the Ripp headers? It seems like a great combo for all around power gains. What I'm wondering is can the stock JK Rubi clutch, trans (6 speed), driveline etc handle the additional power without breakage/wear issues? I would be running 35's on it as well. I'm planning my winter build of my now stock 2010 Rubi Unl. Thanks everyone for the input..
So, I can't answer your question directly as I have the Gen 1 SC, but just added the Long-Tube Headers and a Tune from the Dynoshop in Santee, CA. The dyno power run was done after several tuning runs and therefore was a little hot so I did not get all the power I expected, but showed 206 whp at 3900 rpm. Torgue was really good, but I don't have the number right here in front of me to report. I have an automatic with 3.73 gears, so I can only assume gearing would make a difference is both power and powertrain stain.
I will be lifting first AEV 3.5 inch premium, then gearing to 5.13 and 35 inch Goodyear Wrangler MT/R w/Kevlar (35X12.50R17LT) and AEV rims.
TDmaster is offline
post #78 of 133 Old 12-08-2010, 02:42 PM
RIPPMODS
Vendor
RIPPMODS's Avatar
The power is locked up in the tune - GEN1 with Black Box's can only "allow" so much power to get out - GEN2 electronics really open the power up - how was the torque (would you be able to forward us a dyno sheet) tech@rippmods.com
RIPPTECH
RIPP Superchargers
2005-2014 Wrangler
2011-2014 Grand Cherokee 3.6 5.7 6.4
RIPPMODS is offline
post #79 of 133 Old 12-14-2010, 01:10 PM
TDmaster
2009 JK Wrangler
RIPPTECH
So, I emailed you the dyno sheet Sunday Night...did you get a chance to look at it. The max HP was actually recorded at around 5400 RPM not the 3900 I said previoulsy. It was also a little jumpy/irregular as far as power curves go. The torgue was pretty good from low rpm and peaked in the neighborhood of 242 ft-lbs at 4080 RPM. My understanding is that the graph picked up right after a shift, but I forgot to ask if that was from first to second, or second, to third.
TDmaster is offline
post #80 of 133 Old 12-14-2010, 03:04 PM
-Zona-
The 3.8 does not suck - its well built engine that does a great job -
Red- 100% agree with, I have done everything from dunk mine in the Pacific in Hawaii to taking it to the top of Black Bear Pass, never had any mechanical issues.
Blue- It leaves alot to be desired, in my honest opionion, but then again I didn't buy it to win any street races or win the Baja.
Originally Posted by cherrybomb05 View Post
Or Zona because he reminds me of charlie sheen
-Zona- is offline
post #81 of 133 Old 12-14-2010, 03:24 PM
Charles
2017 WK
Originally Posted by -Zona- View Post
Blue- It leaves alot to be desired, in my honest opinion, but then again I didn't buy it to win any street races or win the Baja.
The engine is fine for a stock 2-door. The problem is that Chrysler doesn't build the engine to accommodate 37 inch tires on a lifted 4-door (extreme case).
When we start adding MASSIVE amounts of weight and GIANT tires to our Jeeps we're asking a lot more of the engine.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #82 of 133 Old 12-14-2010, 03:51 PM
RIPPMODS
Vendor
RIPPMODS's Avatar
Yes -we saw that to be noted this is a GEN1 Kit with Black Box tuning (our older stuff)
The Torque is clean, the HP seems jumpy, would you be able to get us a sheet with fuel and boost added for comparison?
RIPPTECH
RIPP Superchargers
2005-2014 Wrangler
RIPPMODS is offline
post #83 of 133 Old 12-14-2010, 03:52 PM
-Zona-
Speak for yourself, I have a stock 2dr Rubi.
-Zona- is offline
post #84 of 133 Old 12-14-2010, 03:54 PM
RIPPMODS
Vendor
RIPPMODS's Avatar
Well luckily the supercharger fits JK's with stock tires - No need to change them
RIPPTECH
RIPP Superchargers
2005-2014 Wrangler
RIPPMODS is offline
post #85 of 133 Old 12-14-2010, 04:04 PM
Charles
2017 WK
Yes, I was disagreeing with you.
I also have a stock 2dr Rubi. It's red. Well, my wife does.
Charles is offline
post #86 of 133 Old 12-14-2010, 04:24 PM
Charles
2017 WK
RIPPTECH
Speaking of which, have you guys ever seen anyone SC a completely stock 2-door? I imagine it would be like a rocket.
Charles is offline
post #87 of 133 Old 12-14-2010, 04:33 PM
TDmaster
2009 JK Wrangler
That is exactly why I added the SC and now the long tube headers from RIPP. I can comfortably add the AEV 3.5 inch lift, 35 inch tires and 5.13 gears and get great performance on and off-road!
TDmaster is offline
post #88 of 133 Old 12-14-2010, 04:38 PM
TDmaster
2009 JK Wrangler
Yes, that would be me. I had a completey stock 2009 JK 2-dr Wrangler X. The only other mod I made at the same time as when I added the SC (gen1) was the MBRP T304 Stainless Cat Back Exhaust including a relocation of the Evap Cannister up under the rear axle for safety.
Now, with the Long tube headers, this baby really breaths and just cruises with no effort. Hardly no lag when getting into the throttle, unlike the stock engine.
TDmaster is offline
post #89 of 133 Old 12-14-2010, 04:45 PM
Ben_88Jeep
2010 JK Wrangler
I was looking at DYNO numbers with the cat back exhaust and they are saying about a 25 rwhp gain... has anyone dyno'd the supercharger system with the headers? I'd be curious to see those numbers verses a Gen II with stock headers to see the difference.
The more I look at this system the more I want it.
Ben_88Jeep is offline
post #90 of 133 Old 12-14-2010, 05:22 PM
RIPPMODS
Vendor
RIPPMODS's Avatar
Sure - our stock GEN2 programming delivers 280dt.lbs of trq and 240hp at the rear wheel... its sweet...
RIPPTECH
RIPP Superchargers
2005-2014 Wrangler
RIPPMODS is offline
RIPP Modifications Supercharged JK RIPPMODS JK Wrangler Technical Forum 142 05-06-2015 06:49 PM
Ripp Supercharger Ambulldog TJ Wrangler Technical Forum 62 02-21-2010 08:34 PM
River Raider and RIPP ? swnmcop JK Wrangler Technical Forum 10 09-28-2009 11:16 AM
Ripp Modd problems!!! Need some help!! RelentlessRPM JK Wrangler Technical Forum 9 09-15-2009 12:20 PM
Does anyone have the RIPP supercharger? badazzelanore JK Wrangler Technical Forum 17 04-23-2009 12:31 AM
