RIPP SC field repairs: Serpentine belt - Page 2 - JeepForum.com
post #16 of 40 Old 02-11-2013, 01:16 PM
neverhide34
2011 JK Wrangler
Not sure why I go through so many. I do some driving in the mud but nothing crazy. And I make sure to clean out the engine compartment. I have 30k and I've been through 4. 2 when I lived in the high desert southern California. I just make sure to always have a spare.
Keep Calm, Chive On
neverhide34 is offline
post #17 of 40 Old 02-11-2013, 01:17 PM
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
Originally Posted by ArticRubi View Post
I know I should avoid it, I regret it pretty much every time I get in it...sometimes my inner redneck needs to be satisfied, what can I say?
You have rednecks in MA? I thought some of ours escaped GA.
neverhide34...looks like debris from the mud and sand may be the culprit. That sucks because mud is so much fun to play in. But I avoid it nowadays, not as limber as I used to be, and don't like crawling underneath to clean it off.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #18 of 40 Old 02-11-2013, 01:34 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
I'm a Carolina boy, moved up here 2 years ago....but hell yes there are rednecks up here....a slightly different breed....definitely still redneck though.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #19 of 40 Old 03-03-2013, 03:39 PM Thread Starter
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Just finished installing the SC and took it for a spin.
One word, daaaayum!
Hitting the shower and then going for a drive.....
Sent from my over priced iPhone.
PhatBasturd is online now
post #20 of 40 Old 03-04-2013, 06:53 AM
HappyTrails
One word, daaaayum!
I couldn't have said it better myself. Although, I recall saying a certain 4-letter word that starts with "S" and having the deer-in-the-headlights look on my face.
post #21 of 40 Old 03-05-2013, 07:16 AM
mello
For those of you who are throwing belts, check belt alignment at super charger pulley. I did not throw but squeaked on cold startup had to shim it. As far as replacing belt you do not have to take Supercharger off. Just unbolt charger from mounting bracket, disconnect cooling fan connector, slide charger back, and you can slip belt between power steering pulley and charger. It is a ten minute job.
mello is offline
post #22 of 40 Old 03-05-2013, 10:21 AM Thread Starter
PhatBasturd
1976 CJ7
Mello - Can you elaborate on the shim? I have the same issue with squeaking. Thanks.
post #23 of 40 Old 03-05-2013, 11:17 AM
mello
Will be hard to explain in text but here we go. Standing on the passenger side looking over the fender at the belt. My belt was coming off ps pump straight, going under charger roller straight, then being pulled back to firewall onto charger pulley. As the belt went over pulley and under roller on other side of charger it was riding straight. The charger is bolted to bracket with bolts at top that have spacers and studs at bottom which are the rollers that double as spacers. I took two 5/16 washers and cut about 40% of there circumference out. I then unbolted charger from bracket not from block. I slid a washer between top spacer that uses bolt on passenger side and bracket that bolts to block. I slipped other washer between roller spacer on passenger side and the bracket that bolts to block. Tightened everything back up and now belt rides perfectly straight and does not squeak.
mello is offline
post #24 of 40 Old 03-05-2013, 11:28 AM Thread Starter
PhatBasturd
1976 CJ7
Originally Posted by mello View Post
Will be hard to explain...
Perfect - I know exactly what you are saying. Thanks!
post #25 of 40 Old 03-06-2013, 03:45 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Took the big plunge today and ordered the Gen2 kit for my 08. Ripp gave me a great deal pre-Moab...look fwd to getting it and install prior to Moab EJS this year. Price includes the Diablo programmer with info to set up the ECM. Keep you posted. To keep on thread, I spoke at length to the technical rep and we walked through the procedure for a belt replacement. Seemed in accordance with mello above...not a big deal as I see it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #26 of 40 Old 03-06-2013, 05:41 PM Thread Starter
PhatBasturd
1976 CJ7
A couple of tips for your install that might make it easier:
1 - Test fit your grill before tightening down all the hose clamps for the intercooler and its piping.
2 - I installed mine without removing the EGR tube (as others have stated) - just be gentle when removing/installing upper intake plenum.
3 - You have to cut out part of the battery tray where the OEM air box sat or your power steering lines will pinch/rub once you jam the #1 tube for the intercooler in place. The instructions don't tell you this, but I managed to figure out that's what I was going to have to do and also found a set of instructions from a earlier generation ripp install that does include this step.
4 - Screws for MAP sensor - replace with a hex head version of the same size. Much easier to use a small box end wrench to put the new sensor in.
5 - Invest in a 10mm socket with the built in swivel for the #8 bolt on the intake plenum. Sears has them.
6 - The instructions recommend that you mount the plenum that the air filter attaches to, to the SC before you mount the SC to the engine although it is not required at that particular point. Normally you wouldn't do it until later in the instructions at step 11.
I waited until step 11 and it is a major pain, if not impossible to get on my 2010 without trimming the plastic radiator fan support brackets and unbolting but not removing the fan connector and temperature sensor that is located on the passenger side of the radiator. I think having done it this way, might give me a little more room to slide the SC forward and install a new belt in the future per Mello's instructions above.
post #27 of 40 Old 03-06-2013, 08:22 PM
HappyTrails
You are going to be very happy with the performance increase.
post #28 of 40 Old 03-07-2013, 08:15 AM
mello
What set up do u have gears, tire size, and trans. I have 35's , auto, and stock 4:10 gears. The power is good don't get me wrong i love it but not amazing like everyone says. I did just order 5:13's last week and I expect that will put me in the amazing category.
mello is offline
post #29 of 40 Old 03-07-2013, 09:04 AM
HappyTrails
I have 37's, auto and 5.38 gears. The regear will help a lot. I ran the 37's on 4.10's for a while before regearing to 5.38's. Now I can literally smoke those 37's (wouldn't recommend it though, until you get chromoly axle shafts...just ask ArticRubi about his experience, LOL).
post #30 of 40 Old 03-07-2013, 09:31 AM Thread Starter
PhatBasturd
1976 CJ7
35's, 5.13's and auto here. I've unintentionally chirped the tires a time or two or three...
