RIPP GEN II Stage II on the Colorado Mountain Passes and Off-Road. - JeepForum.com
post #1 of 98 Old 11-21-2010, 07:58 PM Thread Starter
Charles
2017 WK
Here is the video of the RIPP GEN II Stage II kit on the mountain passes of Colorado. Being able to conquer the mountain passes was the reason I bought the kit and it took care of them no problem. Enjoy the vid!
YouTube - RIPP GEN II Stage II Supercharged Jeep JK Unlimited in the mountains of Colorado.
Charles is offline
post #2 of 98 Old 11-22-2010, 04:58 AM
Prot
Prot's Avatar
2014 JK Wrangler
The engine light and traction control light are on the entire time.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #3 of 98 Old 11-22-2010, 05:17 AM
Warlord2
ya he pointed that out during the video, I guess its running too rich and ripp is working on a fix?
looks like its a blast to drive now, I sure wish they had put a even half decent engine in these jeeps.....
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #4 of 98 Old 11-22-2010, 06:33 AM Thread Starter
Charles
2017 WK
Incorrect. The engine light is only on on the way home. It is running a little rich probably because I am at altitude. I am the first guy running the RIPP 2.0 tune at altitude. It will be fixed this week. I'll keep you posted.
The ESP light has nothing to do with RIPP. I turned it of permanently.
'07-Present Wrangler's Control System - ESP Off - Jp Magazine
Charles is offline
post #5 of 98 Old 11-22-2010, 02:04 PM
Ben_88Jeep
2010 JK Wrangler
"what the hell? a jeep!" Next time stop and help a fellow Jeeper out! haha! The SC sounds sweet. Looks like a huge improvement.
Ben_88Jeep is offline
post #6 of 98 Old 11-22-2010, 08:26 PM
RIPPMODS
Vendor
RIPPMODS's Avatar
The traction light is the OP traction override - the CEL has been forwarded to our Calibrator and will likely be part of the tune update... Our Calibrator believes it to be a false codes triggered by the rear bank O2's - it does not effect the performance.
RIPPTECH
RIPP Superchargers
2005-2014 Wrangler
2011-2014 Grand Cherokee 3.6 5.7 6.4
RIPPMODS is offline
post #7 of 98 Old 11-23-2010, 07:06 AM
442Wrangler
In like Flynn.
442Wrangler's Avatar
Someone want to explain to me how a supercharger increases gas mileage and horsepower?
I've only help put superchargers on muscle cars and those just dump extra gas into the cylinders so what's the deal with this?
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #8 of 98 Old 11-23-2010, 07:40 AM
jstrubberg
2009 JK Wrangler
Superchargers dump more AIR into the cylinders, not fuel. The OP has a very specific problem int hat he is driving regularly at 8k+ feet of elevation. The not-so-stout Jeep engine is starving for enough oxygen to make horsepower. The supercharger takes care of that.
jstrubberg is offline
post #9 of 98 Old 11-23-2010, 09:43 AM Thread Starter
Charles
2017 WK
The Roots type blower will never increase efficiency. However, the centrifugal type kit (RIPP) will because it is less of a parasitic load on the engine. It works by increasing the thermal (how much energy is produced per explosion) and volumetric efficiency (how much of the cylinder fills up) of the engine.
A well engineered engine fills up 80-90% of the combustion chamber at BDC. If you force some air in there you're getting 10% more air and when the mixture is compressed and explodes it explodes with a greater thermal efficiency.
Once it's supercharged the engine does not need to be run as hard to achieve the same results so drivers tend to back off the throttle.
One more advantage of supercharging is running lower RPM's which isn't really related to fuel efficiency but it does reduce wear on cylinders and pistons and the inertial forces on the pistons and rod assemblies.
Charles is offline
post #10 of 98 Old 11-23-2010, 06:00 PM
saceone
cool vid, thanks for posting!
beautiful scenary btw
saceone is offline
post #11 of 98 Old 11-23-2010, 08:32 PM
442Wrangler
In like Flynn.
I know that superchargers put more air in. But they generally work at much higher RPMs than fuel efficiency so they result in more gas being used as well.
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #12 of 98 Old 11-23-2010, 08:37 PM Thread Starter
Charles
2017 WK
They result in more fuel being used because to keep the air fuel ratio correct you have to put in more fuel with more air. The RPM range is different for centrifugal blowers and Roots type blowers.
Charles is offline
post #13 of 98 Old 11-23-2010, 08:39 PM Thread Starter
Charles
2017 WK
RIPP GEN II Stage II off-road.
Here is the kit off-road. It did well off-road but, like I've always said, it doesn't really need any more power off-road. The Roots blower guys always say that the RIPP kit doesn't provide power where the Jeep needs but, as I reaffirmed today, it doesn't need anymore power-off-road with the 4:1 t-case. The RIPP blower kicked in a few times but it always did fine before. Take a look.
YouTube - Supercharged Jeep Offroad
Charles is offline
post #14 of 98 Old 11-24-2010, 04:06 AM
Prot
Prot's Avatar
2014 JK Wrangler
I think your camera man needs a supercharger to help fill his normally aspirated lungs. Man, that guy was breathing heavy.
Your Jeep does not squeak like mine.
I still wish the powerband was at a lower rpm, which is why I have trouble justifying this purchase.
Prot is offline
post #15 of 98 Old 11-24-2010, 10:32 AM
MrOrange
2009 JK Wrangler
I'm guessing the cameraman was riding with the driver so he was sprinting up the hill to record the passes.
@OP, thanks for the vid. I know this is something on my wish list that's too far out to even see at this point, but I always like to day dream and collect info.
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
Moved to Wy and Jeep feel weak on highway mountain passes...? GCarpJeep YJ Wrangler Technical Forum 15 07-29-2009 06:37 AM
YJ Road Trip Advice...Colorado! B-ROM YJ Wrangler Technical Forum 20 03-01-2009 09:41 AM
97-03 TJ 4.0 Jet Stage 1 or Stage 2 Chip John Thomas TJ Wrangler Technical Forum 6 03-26-2007 07:54 PM
Mountain Off Road hillbillyyj YJ Wrangler Technical Forum 7 03-08-2007 05:46 PM
Engine stalls going UP and DOWN Colorado mountain Passes. PLease Help forrestjeep YJ Wrangler Technical Forum 14 06-26-2006 11:11 PM
