Ring & pinion swap require new Carrier?! 09 JK"X" wanting 4.88s - JeepForum.com
post #1 of 6 Old 03-28-2012, 05:06 PM Thread Starter
09YellowJK
2009 JK Wrangler
I have done a search and only found open ended questions about what I am trying to find. I am about to install 35's on my 09 "X". I have researched and decided 4.88s should be the happy ratio for me. I logged on to a few websites selling the gears, and ran across MANY more versions and questions than I expected.
I have learned that my Dana 30 Front axle requires "reverse cut" gears. The rear Dana 44 is "standard". But occassionally i see notes talking about wether the stock gears/carrier are "3.73 and higher, or 3.73 and lower". I am confused about what I am reading and require. I am 90% sure my BASE model X has crappy 3.21 gears (or worse). Does this mean I have to buy a new "carrier" to mount the 4.88 ring gear to?!
2014 JKU Rubicon - In the planning phase
'09 Wrangler "X"(SOLD)-4" Rough Country Lift, 35" Falken All Terrains, 4.88s, D30 w/Aussie Locker Sleeved/Gusseted, D44 w/Detroit TT
09YellowJK is offline
post #2 of 6 Old 03-28-2012, 05:07 PM Thread Starter
09YellowJK
2009 JK Wrangler
Also, where can I find the FACTORY gear ratio (original owner)? And is there an easy or good deal company to order my geras & install kit from?
post #3 of 6 Old 03-28-2012, 07:08 PM
spedly
2011 JK Wrangler
The d30 has what is called a carrier break. That means 3.73 and up numerically use one carrier and anything under 3.73 such as 3.21 uses another carrier.
If you ever plan on a locker now would be the time to do it since you most likely need a new carrier anyway. If you don't want a locker you should be able to find an open carrier for 3.73 and up gears for under $100 new.
4ws.com has the cheapest price I have seen on gears. $540 gets you front and rears with master install kits.
Poser Jeep.
spedly is offline
post #4 of 6 Old 03-28-2012, 07:15 PM
spedly
2011 JK Wrangler
As far as seeing what gear ratio you have jack up the back and see how many times the driveshaft turns for 1 rotation of the tires. a little over 3 is 3.21 a little over 4 is 4.10s and 3.73s is almost 4.
Poser Jeep.
spedly is offline
post #5 of 6 Old 03-29-2012, 07:23 AM Thread Starter
09YellowJK
2009 JK Wrangler
I had never heard of that 4ws.com before. HOLY CRAP, they have awesome prices and free shipping! That new carrier (3.73+) is only $60.
post #6 of 6 Old 04-19-2012, 03:36 PM Thread Starter
09YellowJK
2009 JK Wrangler
Does the D44 require a numerically higher carrier/locker?
replace ring and pinion because of bad carrier bearing DieselDog1 TJ Wrangler Technical Forum 2 04-21-2011 04:44 AM
carrier and ring and pinion deal ldso YJ Wrangler Technical Forum 1 12-30-2010 05:56 PM
will yj carrier and ring and pinion fit tj 30 derrick_ozzy TJ Wrangler Technical Forum 7 04-13-2009 06:34 PM
can i use d30 ring pinion and carrier from a tj in a yj ozo101 YJ Wrangler Technical Forum 2 02-22-2009 03:43 PM
Ring & pinion swap?'s DesertTJ TJ Wrangler Technical Forum 2 10-20-2006 02:57 PM
