Is this the right way to lift it? - JeepForum.com
post #1 of 7 Old 03-16-2010, 04:58 PM Thread Starter
JKommuter
2009 JK Wrangler
I had a Teraflex Leveling Lift on my 2009 JK Unlimited X. I took it off last weekend because I started getting a sustained wobble after hitting certain bumps on the way to work. Checked torques, bushings etc... and couldn't fix it so I removed the lift and now it's rock solid on the bump that used to make it wobble every time. I didn't have it aligned, but I suspect it was caster related.
Anyway that's the back story, now the question. How do I lift it correctly? Am I missing anything with the lift listed below?
  1. Teraflex 2.5" kit with Shocks.
  2. JKS Adjustable front Track Bar.
  3. Teraflex Monster Adjustible Lower Control Arms.
(I will use the track bar bracket in the kit for the rear.)
This comes to around $1150 at northridge 4X4...
JKommuter is offline
post #2 of 7 Old 03-16-2010, 05:05 PM
owtdorz
2009 JK Wrangler
For a little more you can do the Rock Krawler 3.5" mid arm flex.
'09 Detonator Yellow 4dr Rubi, Bestop Element doors, Rugged Ridge XHD w/stinger, Warn 9.5ti, 3.5 Rock Krawler, Woods driveshafts, Hella 500 aux lights, 35x12.5x17 BFG KM2<< THEY SUCK
owtdorz is offline
post #3 of 7 Old 03-16-2010, 05:11 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
What you had sounds more like bump steer than DW - usually due to the track bar and drag link not being parallel. Your lift seems complete by most standards, esp with adj CA and track bar for front.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 7 Old 03-16-2010, 05:22 PM
TurtleSlinger
2009 JK Wrangler
Only other thing I see not listed that a lot of people including myself have done to help minimize it is a new stabilizer. Other then that sounds like you have good stuff.
Current stable:
09 JK Rubicon 35's and 5" lift - modded
09 WK Limited 5.7 Hemi OVERLAND - stock
07 MB AMG E63 "My 11 sec sedan" - modded
11 HD NightRod Special - modded
TurtleSlinger is offline
post #5 of 7 Old 03-16-2010, 05:26 PM Thread Starter
JKommuter
2009 JK Wrangler
Forgot to mention that I already have a Teraflex Steering Stabilizer. (Unfortunate floor jack incident...)
post #6 of 7 Old 03-16-2010, 05:39 PM
TurtleSlinger
2009 JK Wrangler
ahhh...ok...just thought it was worth a mention if you didnt have it already.
Current stable:
post #7 of 7 Old 05-23-2010, 11:27 AM Thread Starter
JKommuter
2009 JK Wrangler
I'm going to revive an old thread of mine here for a little bragging, uh, I mean an update.
Anyway I eventually purchased the TF 2.5 Coil kit w/shocks, Teraflex Adj Trackbar, and Teraflex front lower control arms. Did it myself in my garage. It took me 7 hours, but after my leveling lift install and removal I'm pretty familiar with the process.
I think it looks good and I don't hate it with the stock 32's, but I will get some wider 33's after I wear these out. I've put about 100 miles on it since Friday afternoon and it drives great. No wobble, firmer than stock, but not harsh.
Here it is stock
After the TF leveling kit
Now with the TF 2.5" coil lift
I haven't driven it on the road that without fail caused the wobble with the leveling kit yet but I'm betting it will be fine. I betting caster was my problem. I hope I'm right.
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
