Ride difference between long and short arms - JeepForum.com
post #1 of 8 Old 01-07-2009, 05:45 PM Thread Starter
FatBuoy
FatBuoy's Avatar
I'm still having my internal debate. It looks like my cost difference between long arms and regular adjustable will be about $500. I've got a buddy who will help install either, so installation cost on the LAs would be minimal. Who out there has experience driving both setups both on and off road? I understand the more articulation aspect, but is there a huge difference on the pavement in regards to ride quality? I will be going to 37s eventually, but will keep the lift at 4" with different fenders for clearance if that makes any difference.
Thanks!
Black Rubi JKU with a rompin' stompin' 6.1 magnuson supercharged hemi!
FatBuoy is offline
post #2 of 8 Old 01-07-2009, 05:56 PM
HITMONEY
RubiKong's Trainer
HITMONEY's Avatar
Physics say the LA will ride smoother.. now whether or not it will be enough to notice in the drivers seat is another question since the JK already has pretty long arms to begin with.. kinda like mid length arms.
The more parallel your control arms are to the ground the less shock, or jarring, is transmitted up into the body but rather dissipated through the vertical movement of the control arms... this of course is not counting the harshness of your shocks.
EDIT: But IMO my LA rides every bit as smooth if not smoother than it did stock and definitely smoother than some other lifted JK's I've ridden in. The only one that is noticeably smoother that I have experienced has been a RE LA.
I Wheel a Wave Killer!
08 Unlimited RubiKong
Pics And Info Of My Junk
YouTube Channel
FaceBook
HITMONEY is offline
post #3 of 8 Old 01-07-2009, 11:41 PM
themaniam1
themaniam1's Avatar
Ok I feel that I can speak from alot of experience here. The LA will ride much smoother then a SA of 4" or greater. I have had three wranglers with short arms and then upgraged to long arms and the results were the same each time, wow they ride smooth. My wife infact will not have anything but long arm lifts. Our TJs went from bumpy and a little scary on the highway to smooth and no worry driving. We went right from factory to LA with our JK and the same thing, smooth and no worries. They wheel just awesome on the rocks with great travel and articulation. In some situations they will scrape on the rocks but I have yet to every regret getting them. For $500 more I would not even hesitate. They even look good too.
Also have a '06 Rubi LJ, Auto
themaniam1 is offline
post #4 of 8 Old 01-08-2009, 10:06 AM
Xtremjeepn
On a TJ it makes a big difference. Much less on a Jk. Having experience On a tj is not relevant unless you have done both on a jk? Different animal.
Cole Ford
Xtremjeepn is offline
post #5 of 8 Old 01-08-2009, 12:07 PM
Prot
Prot's Avatar
2014 JK Wrangler
I hear great things about the Rubicon Express kit. If I were starting over, I think I probably would have went that route. Granted, it's a lot more than my basic black diamond kit.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #6 of 8 Old 01-08-2009, 01:13 PM
scrogg
I went from a TeraFlex 4" short arm to a TeraFlex 6" long arm with my JK and the difference is very noticable. The on road mannerisms of the LA are superior to the SA. The ride is smoother and the vehicle feels more stable than previously. And the body roll even seems to be less than what the 4" springs allowed, not sure if the LA's have anything to do with that or not.
I feel confident traveling down the freeway a 70+ mph with the LA's. The short arms gave me the feeling that I had to hold onto the steering wheel, even though I could let go and it still drove straight. The LA's seem to transfer feedback from the surface to the steering wheel in a far better manner than the SA's did.
One another note, when I first had the swap done it felt so different just going through the gutters in the neighborhood. It's hard to explain but it felt way cooler. After talking with Carl at TeraFlex Plus, he explained that it was probably due to the angle of the LA's vs the SA's. The SA's were at a steep enough of an angle that it was almost jarring as opposed to the LA's.
Amazingly smoother by far is all I can say. I am very pleased that I upgraded and would highly reccommend it to anyone that is seriously considering it.
scrogg is offline
post #7 of 8 Old 01-08-2009, 02:41 PM Thread Starter
FatBuoy
FatBuoy's Avatar
There seem to be some differing opinions, as there always are, but I think the answer will be LAs. If I heard, "you will not be able to tell a difference on a JK unless you have 2 ft. of lift, don't waste your money" I would say no, but for the $500 it sounds like a good idea now rather than regretting not doing it later.
Thanks again Jeep gurus!
FatBuoy is offline
post #8 of 8 Old 01-08-2009, 03:20 PM
HITMONEY
RubiKong's Trainer
HITMONEY's Avatar
It is WELL worth the extra $500.00.
YouTube Channel
FaceBook
HITMONEY is offline
What's the difference between Long-Arm and Short-Arm Suspension? IMYY4U TJ Wrangler Technical Forum 43 01-14-2015 08:55 AM
Difference between short and long arm lift? DocJake JK Wrangler Technical Forum 3 12-03-2009 09:52 AM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Difference between long & short arm lifts? FrankGG TJ Wrangler Technical Forum 18 08-28-2007 07:33 AM
Short Arm & Long Arm..What's the difference? blackjeep04 TJ Wrangler Technical Forum 2 10-31-2004 09:32 PM
