Ricks 2012 DD/Weekend Warrior Build - JeepForum.com
post #1 of 116 Old 09-20-2012, 07:09 PM Thread Starter
maniacal_rick
Hello everyone. I've decided to start my build thread...Not sure if my project is worthy of a build thread but hopefully it gets there sooner or later. This is my first Jeep Wrangler. A 2012 Sport, and I love this vehicle. It didnt have 200 miles on it before I started modding.
The premise of my build will be a functional Daily Driver and Weekend Warrior. My GF drives the Cherokee so I need to keep this as reasonably streetable as possible.
So...on with the build..
The Jeep the day I got it, and a few trail pics:
IMG_1001 (Small).JPG   IMG_1002 (Small).JPG   IMG_1010 (Small).JPG   IMG_1123 (Small).JPG   IMG_1139 (Small).JPG
maniacal_rick is offline
post #2 of 116 Old 09-20-2012, 07:16 PM
kade
welcome !!!
every jeep and project is worthy of a build thread!!!!!
have fun love the white pm if you need help with any thing
MY BUILD 2012 JKU
http://www.jeepforum.com/forum/f96/kade-2012-jku-build-1305112/
kade is offline
post #3 of 116 Old 09-20-2012, 07:23 PM
scratchkenny
2011 JK Wrangler
What gearing do you have? what do you plan on doing? lift, gears, tires,,, Ill be watching Iam in the same boat. got a 2011 with 321 gears and torn on what to do.
scratchkenny is offline
post #4 of 116 Old 09-20-2012, 07:24 PM Thread Starter
maniacal_rick
I started by stripping the factory stereo. I started out with the plain jane 6 speaker/CD player/BT system (130 I think). I added a Pioneer AVIC-x930BT with Back Up Camera, Sirius module and Steering wheel controls. I liked the Pioneer because of the ability to stream most anything from my ipod to the head unit, so for example if there is a GPS program I like better than the navigation that comes with the Head unit, I can use that instead. I can also stream netflix
Components used to install the stereo:
Standard Double Din Dash Kit
Wiring Harness - XSVI-6522-NAV (Metra)
Steering Wheel Control Interface - ASWC (Metra)
Pioneers Sirius Adapter - CD-SB10
Pioneers Sirius Module - SC-C1
Pioneers Backup Camera - ND-BC5
Crutchfield states the ASWC doesnt work because of the Jeeps CanBus system..but I can confirm the system works perfectly and I had no issues installing.
post #5 of 116 Old 09-20-2012, 07:27 PM Thread Starter
maniacal_rick
I added my amps and a Sub. All Polk equipment. The Amps are mounted on the back gate and the sub is in a box I built out of MDF. I dont have any pics of the install process or box build. I plan on adding or building an instatrunk so all of these components will be relocated and I will probably build another sub enclosure when I buy/build the insta trunk.
post #6 of 116 Old 09-20-2012, 07:30 PM Thread Starter
maniacal_rick
Next came the hitch so I can lug around my Jet Ski.
Kudos to Quadratec for a fantastic hitch system. The instructions were perfect with color pictures, even came with a Mopar receiver cover. All for around $80 I think. I called the dealereship and they wanted almost 300 for the receiver and the wiring.
IMG_1171 (Small).JPG   IMG_1172 (Small).JPG   IMG_1175 (Small).JPG   IMG_1176 (Small).JPG
post #7 of 116 Old 09-20-2012, 07:31 PM Thread Starter
maniacal_rick
Threw in the CB with the Quadratech Antenna Mount and a Firestik. Mounted the CB in the center console. I HATE wires showing and things just randomly mounted anywhere. I like the look of factory
post #8 of 116 Old 09-20-2012, 07:36 PM Thread Starter
maniacal_rick
And finally, last update until more parts come in. New Rubber and Shoes. Procomp MT's in a 315-75/16 with Procom wheels.
Two things im not sure on though...I dont know if I want to leave the center caps chrome and I dont think I like the white lettering on the outside
Oh...and AEV's Procal to re-calibrate the speedo and TPMS errors.
IMG_1178 (Small).JPG   IMG_1179 (Small).JPG   IMG_1180 (Small).JPG   IMG_1181 (Small).JPG   IMG_1182 (Small).JPG
IMG_1183 (Small).JPG   IMG_1187 (Small).JPG   IMG_1193 (Small).JPG   IMG_1185 (Small).JPG
post #9 of 116 Old 09-20-2012, 07:43 PM
kade
about the amps on the tail gate
1. dont open it when it rains.
2. that where the air hole is for the jk so moisture getting in a high possibility
3. if you got them on and the extra tire like a 33 or 35 (yes 35 fit i got it on) thats to much weight
i want to get some subs and amps to but nut sure where to mount it
it was a good idea i just want to make sure you wont be sorry later (before you switch it)
MY BUILD 2012 JKU
kade is offline
post #10 of 116 Old 09-20-2012, 07:45 PM Thread Starter
maniacal_rick
No dirty pics yet...still need to trim the Pinch Seams. I'm running 3.21's from the factory so a re-gear will be in my future but honestly the car is completely streetable as is. I still average 20ish mpg around 60 in 5th gear.
The AEV is fantastic. I matched my Speedo against my iPhones GPS after a recal and they are spot on. (and no annoying TPMS warnings).
I really wanna add Rubicon Sliders if I can find a decent set. Im in Florida so there arent many rocks here to worry about. Im going to run Metalcloak's ARB Edition Dual-Rate Lift Kit which should be here next week. Plus a few other goodies I ordered from KOR.
Still need to hash out lighting, and what im going to do about gearing and the from D30 for strength. Ill probably just sleeve/gusset it at the same time the gears get done...but I need to see how it handles here first before I decide on the gearing (thinking 4.56 or 4.88's)
post #11 of 116 Old 09-20-2012, 07:47 PM Thread Starter
maniacal_rick
Thanks, itll be fine for now. I'm not even mounting the spare until I get a rear bumper with a carrier...so there isn't any weight on it at the moment.
I tell you what, its actually worked out very nice. Everything is black and even in the day you cant see it from outside the jeep with the tint. I really like the mounting location...but like I said before Ill rerun everything once I figure out what type of trunk system I wanna run with.
post #12 of 116 Old 09-20-2012, 07:54 PM
dvdsjk
dvdsjk's Avatar
Nice build so far!! Love the white! A blacked out grille would look awsome on her also!!
dvdsjk is offline
post #13 of 116 Old 09-21-2012, 06:23 AM Thread Starter
maniacal_rick
Thanks! Im considering either doing the whole grill or just the vents/headlight areas. Not sure yet.
post #14 of 116 Old 09-21-2012, 11:32 AM Thread Starter
maniacal_rick
Sneak Peak at things to come. Big thanks to Jason at http://www.krawloff-road.com/ for the speedy delivery!!
post #15 of 116 Old 09-21-2012, 02:11 PM Thread Starter
maniacal_rick
Pinch Seams trimmed, this pic is before seal and paint obviously. Have to run to the store and find some gloss white...apparently the can I had was spent.
2012 Rubi Build-Should be done this weekend USICE JK Wrangler Technical Forum 25 12-19-2011 09:11 PM
Weekend warrior turned DD 97lon TJ Wrangler Technical Forum 13 12-18-2011 08:27 PM
Prepping rig to become a weekend warrior - anything I need to do? Sparty TJ Wrangler Technical Forum 2 09-12-2009 11:44 AM
Daily Driver...Weekend Warrior hilton00 TJ Wrangler Technical Forum 37 02-25-2009 11:46 PM
