Reverse Rake - JeepForum.com
post #1 of 19 Old 05-22-2013, 09:27 AM Thread Starter
LBrook
Reverse Rake
So, I've had a teraflex leveling kit on my 2 door JK for a few years now, and decided that it was time to get a few more inches of lift. I added 18/59 Coils to my JK. About 6 weeks ago. I feel like the front of my JK sits way higher than the back now. It doesn't seem level. I have a few questions about this set up..
Is it just me, or is there a legitimate reason that the front seems so much higher than the back?
How can I measure to see if everything is level? Should I measure from the bottom of the bumpers, fenders, frame, etc?
Is it safe to say I'm running ~3" of lift now? If so, what shocks should I go with?
Also sometimes when I hit bumps at speed (30-35mph) with this set up, my jeep goes into a death wobble that can only be stopped by completely stopping the jeep. Should I be thinking about a track bar bracket/ adjustable track bar or just a realignment?
'08 JK- Teraflex Leveling Kit and 33x12.5
My Build--
"There are lies, **** lies, and statistics" -Mark Twain
LBrook is offline
post #2 of 19 Old 05-22-2013, 09:58 AM
JTPhoto
JTPhoto's Avatar
18/59 should on their own give you a level ride. If anything the back should be higher then the front. On my Unlimited it takes a 3.5" spring upfront to level my rear #59 with TF 2.5" spacer.
What height TF leveling kit do you have?
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #3 of 19 Old 05-22-2013, 10:48 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
You are not describing "a" death wobble. You are describing "the" death wobble (if the oscillations go away as you slow its not death wobble - its shimmy!).
Several things contribute - including "rake". When the vehicle is higher in the front the castor relative to frame is decreased (so sway has a greater effect on the centering that castor relative to road provides) - increased castor adds to the positive feedback side of the wobble equation. BUT thats not to say the rake is the CAUSE. The cause is the perfect storm of loose steering, ball joints, alignment, geometry, non dampening of the feedback etc. This is what makes it a challenge to correct.
There are threads up in the stickies that address wobble - take it step by step (do NOT assume just DO) and you should be able to work it out. As to the actual frame heights a body shop might inform you of the frame measuring points - I have a good relationship with my local body frame shop and they let me look through the books (its all on computer now lol) as needed.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #4 of 19 Old 05-22-2013, 01:30 PM Thread Starter
LBrook
I have the standard Teraflex Leveling kit. 2" spacers in the front, 1" spacers in the back.
My Build--
LBrook is offline
post #5 of 19 Old 05-22-2013, 01:42 PM
MountainMan864
Look up Carolina squat lol
MountainMan864 is offline
post #6 of 19 Old 05-22-2013, 01:46 PM
JTPhoto
JTPhoto's Avatar
You can pull the front 2" spacers out and remove all together or replace with 1" and try that.. A little rake down in front is better then nose up..
^^Jeff^^
JTPhoto is offline
post #7 of 19 Old 05-22-2013, 02:03 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
You wouldn't say that headed towards a berm jump at 70 mph!!!
post #8 of 19 Old 05-22-2013, 02:25 PM
A_Ninja_Racer
But you also Probably wouldn't be in a jeep!
A_Ninja_Racer is offline
post #9 of 19 Old 05-22-2013, 02:34 PM
chesapeakesoja
Exactly what came to my mind as well :rofl
"We must reject the idea that every time a law is broken, society is guilty rather than the lawbreaker. It is time to restore the American precept that each individual is accountable for his actions."
Ronald Reagan
chesapeakesoja is offline
post #10 of 19 Old 05-22-2013, 04:05 PM Thread Starter
LBrook
Haha unfortunately, that's what I feel like my jeep looks like right now.. I'm putting new shocks on soon. I think I'm going to pull one of the 1" spacers from the front when I put the shocks on.
My Build--
LBrook is offline
post #11 of 19 Old 05-22-2013, 04:07 PM
222Doc
222Doc's Avatar
off road its better to have it a bit down then up. when you get virtical its the little things that mean the most.
222Doc is online now
post #12 of 19 Old 05-22-2013, 04:41 PM
Scormunch
When I put 18/59 springs in, I had to take out one of the two front Teraflex spacers so it would sit level.
Scormunch is offline
post #13 of 19 Old 05-22-2013, 06:05 PM Thread Starter
LBrook
Did you take both 1" spacers out on each side in the front? or just one 1" spacer per side on the front?
My Build--
LBrook is offline
post #14 of 19 Old 05-22-2013, 06:15 PM
Scormunch
Correct. I left in one spacer per side and the rear spacers plus the springs.
post #15 of 19 Old 05-22-2013, 06:32 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Let us see a pic.
2009 JK Rubicon
Shrockworks Mid-width Bumper, Warn 9.5Ti Winch; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - 8/2007
Rubicon - 9/2008
Thunderstrike is offline
