Replacing stock wheels - JeepForum.com
post #1 of 4 Old 07-05-2013, 03:53 PM Thread Starter
takeitsleazy
First off, I dont want to replace my tires yet- there is no resale for them where I live, so I may as well use them. In the meantime, the 16x7s im running are godawful ugly, and im looking into replacing them. Would a set of 16x8s be compatible with my stock 225 75 16s, or should I buy 16x7s? If the latter, would that limit my tire width on future tires? (33s) Id just rather not cause any harm to the tires I have
2013 JK 2DR 3.6L, 1991 XJ 4DR 4.0L, Wife:2008 JK 4DR 3.8L
takeitsleazy is offline
post #2 of 4 Old 07-05-2013, 04:01 PM
T00THD0C
You can use the existing tires on an 8" rim and get bigger tires later or for not much more money, find some take-off wheels and tires on Craigslist. A lot of them are like new with low miles. You could even go down to an inexpensive 15" wheel and save money by buying a 33" tire for the 15" wheel. Lots of people do that.
T00THD0C is offline
post #3 of 4 Old 07-05-2013, 04:16 PM Thread Starter
takeitsleazy
A tire purchase will probably wait until im back in the US- and even then ill probably run 16s, just to avoid the brake-rub issue. 16s arent terribly expensive, especially if I get a 5x4.5 bolt pattern wheel and adapter. Ill be researching all of that, but I have yet to read anything on different widths of wheels and the effects it may have on a tire. Thanks for your answer!
post #4 of 4 Old 07-05-2013, 04:21 PM
T00THD0C
You're welcome!
T00THD0C is offline
