Replacing stock speakers - JeepForum.com
post #1 of 15 Old 09-19-2009, 06:53 PM Thread Starter
Weez_1000
I have an 08 JK 2dr and want to replace the stock speakers. What size speakers go in the dash and the sound bar. I would prefer to buy something that fits in the stock openings without much modification. I would also like to change out the tweeters if possible.
BTW: I see crutchfield has a system that says which speakers will fit but many of them are the component speakers that have separate tweeters with a x-over. If i were to use these would i need to install the x-over? or is there one already installed on the stock setup?
Thanks
Weez_1000 is offline
post #2 of 15 Old 09-19-2009, 11:25 PM
McKBrew
JK Wrangler
I think the Quadrtec site has replacement speakers. You might be able to get the dimensions there.
McKBrew is offline
post #3 of 15 Old 09-20-2009, 06:57 PM
devilsfiddle
I believe it is 6 and a half inch speakers. It component ones in the front. I replaced mine with MTX's, you don't have to use component ones for the front, but it sounds better. It is worth it
JK 08 X
devilsfiddle is offline
post #4 of 15 Old 09-20-2009, 09:23 PM
hkenny90
bestbuys computer has all that info.
hkenny90 is offline
post #5 of 15 Old 09-21-2009, 08:24 AM
unsocbl
2011 JK Wrangler
If you buy the component speakers, you defintely want to use the Crossovers!! They make sure the appropriate frequencies go to the correct speakers...if not used, they really sound bad.
unsocbl is offline
post #6 of 15 Old 09-21-2009, 09:57 AM
JkRyder
I kno that all the speakers ( besides the tweets on the dash ) are 6.5, i just did all 4 of mine, replaced with alpine type S , sound is night and day different, with a aftermarket deck though. I have the X package but wtih the hoooks and fog, but when idid the speakers and no head unit, the sound was pretty much the same, little bit better, but now with an aftermarket alpine deck, i can blare the tunes with no distortion, which stock distordted at around 20 or so if i remember correctly, i can put my deck on til my ears hurt and it still is clleeeeeeear.
JkRyder is offline
post #7 of 15 Old 09-21-2009, 10:47 AM Thread Starter
Weez_1000
Thanks for the replies. I think I am going to go with the components for the fronts and will use the crossovers. Also did you install an amp when you upgraded your unit? I dont want to replace the head unit cause its the mygig w/navigation. I would like to install an amp but i get water in my jeep regularly with the roof down or the windows out and not sure i could find a safe place to mount it where it will stay dry.
post #8 of 15 Old 05-03-2011, 11:51 AM
santr97
I'm trying to install component speakers in my dash now... Did you install yours?
I'd like to know where to wire the input for the crossovers. Do I wire it to the back of the radio somewhere?
I got my roll bar speakers in no problem.
santr97 is offline
post #9 of 15 Old 05-03-2011, 01:05 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
My sig has an ideal setup. The components are well worth the trouble.
Mol is offline
post #10 of 15 Old 05-03-2011, 01:08 PM
Mol
Mol's Avatar
I'm trying to come up with a way to water seal the rear storage compartment (where I have my amp mounted). I haven't dove in head first yet, but I'll let you know what I have going on with that when I get it figured out.
Mol is offline
post #11 of 15 Old 05-03-2011, 10:24 PM
jrmandryck
6.5" and just a FWI/IMO I went with marine speakers in the sound bar in case i get water/mud around
truth is so precious that she should always be attended by a bodyguard of lies...
jrmandryck is offline
post #12 of 15 Old 05-04-2011, 09:14 AM
Woodchuck
Woodchuck's Avatar
Not to hijack, but I was wondering about this myself. However, I was wondering if there are any good marine speakers out there that will fit. Mine sees alot of rain and stuff. Any input would be greatly appreciated.
'08 Red Rock Unlimited Rubicon / AEV 2.75" Lift with Remote Reservoir Shocks / AEV Heat Reduction Hood / AEV Front & Rear Bumper with Tire Carrier / AEV Skidplates & Rear Corner Guards / Riddler Diff Covers / Mopar Enhanced Rock Rails / Warn 9.5ti Winch / Mopar Gas Cap Cover / 4.88 Gears / IPF 900xs Drive Beams / Eagle Eye HID Spotlights / Daniel Stern Headlights / 17" AEV Pintler Wheels with 35x12.5r17 BFG Mud-Terrain KM2's / Tuffy Security Drawer / sPod and Benchmark Dual Battery System / Cobra 75 CB / Lockpick with Front and Rear Cameras / Katzkin Heated Seats / Line-X Interior / Hitchsafe Key Vault / and a Trasharoo and a lot more little stuff or just stuff I forgot!!!
____oooo
[ l_,[____],
l---L -[OlllllllO-
( )_) ( )_)-o-)_)
Woodchuck is offline
post #13 of 15 Old 05-04-2011, 09:19 AM
MrOrange
2009 JK Wrangler
You don't have to limit yourself to just marine speakers. Just read the cone and surround material specs. As long as they're not using paper cones or foam surround, they'll be water resistent. A lot of companies are using high tech plasics for these pieces but not advertising them as marine speakers just because they don't come in white yet they're just as water resistent.
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
post #14 of 15 Old 05-04-2011, 09:44 AM
Mol
Mol's Avatar
Come on guys use the search function
The polk audio are marine grade, quality speakers.
Mol is offline
post #15 of 15 Old 05-04-2011, 10:22 AM
captainstabbin
I didn't feel like dealing with the customizing speaker fit since I am basically lazy. I bought the tweeter and regular speaker set from quadratec and installed. Stupid simple easy. Sounds really good. If tou are an apathetic slug like me then get the replacement upgrades from quadrtec. Just my $.02
captainstabbin is offline
Writeup: replacing stock speakers with 165mm ones Janfri YJ Wrangler Technical Forum 11 05-09-2009 11:03 PM
Replacing Speakers Hoobly_Goob YJ Wrangler Technical Forum 9 10-09-2007 06:19 PM
Replacing stock speakers Dypuz JK Wrangler Technical Forum 9 10-04-2007 08:48 PM
Replacing stock speakers NotARedneck TJ Wrangler Technical Forum 8 03-19-2006 03:31 AM
replacing speakers Atropine YJ Wrangler Technical Forum 15 11-06-2001 01:40 PM
