Replacing parking brake shoes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Replacing parking brake shoes
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinAlloy USA and Posi-Lok Cable Axle Disconnect Kits Dana 30 Stainless Steel Door Hinge Pins
Unread 03-29-2014, 03:25 PM   #1
gorillamel
Hi All.
I'm in the process of replacing my rear parking brake shoes since the old ones were shot.
I have a 2008 jk Rubi. I got the assembly taken apart and understand how it is supposed to go together, but just cannot seem to do it.
The problem i have run into is the longer inner spring that holds the shoes in the craddle is neigh impossible to stretch long enough to get over/around the clamp/craddle.
Here is a new shoe with an old shoe along with the long spring (held by the pliers)
The assembly need to get the spring around (inside of)
New shoes w/spring attached. Now just need to get them around assembly into the cradles.
The whole effing shebang...
I looked at a 2007 rubi set up and it only has 1 shorter inner spring and a metal coil clip rather than a long spring like mine.
Any ideas?
I'll see if i can upload photos again...
Mongol Rally summer 2015: http://mongolianpandaexpress.org/index.html
gorillamel is offline   Reply With Quote
Unread 03-29-2014, 04:45 PM   #2
gorillamel
Photos uploaded in OP. :-)
Unread 03-29-2014, 05:01 PM   #3
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
From what I can tell, you are trying to assemble and then place in the brake as a unit. The way I do it is to place the brake shoes in the brackets first, then install the spring. Yes, it takes a big, big pull to stretch the spring, but I insert one end and then grab it with some vice grips and pull like hell....never seen them place together with spring the way you describe.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 03-29-2014, 05:05 PM   #4
gorillamel
I agree with what you say. After a few failed attempts, I called the local dealership and a brake/wheel store who advised to put the shoes together on the spring prior to putting them on the assembly. *sigh* Shows what they know, right?
I'll go suck it up and ask a neighbor for help on the Hulk stretching spring part, since all my other Jeep club friends are on a rock run, ha!
Thanks!
Unread 03-29-2014, 08:04 PM   #5
ridesno4llfe
Thanks!
Actually that is what you do put the spring between the 2 shoes then hold the first one inplace and use the second shoes to levelage and pull the spring to get the shoe inplace
Everytime I sell a jeep I say no more then a new one shows up in my driveway
ridesno4llfe is offline   Reply With Quote
Unread 03-29-2014, 10:59 PM   #6
gorillamel
Finally got them on. Did connect them first but put them on not over the assembly. Two person project. Had to then slide them over to the craddles and assembly.
Wow. Sounds simple to do. Ha! Guess some have to learn the hard way. At least i should never have to do it again.
Thanks for the input.
Unread 03-30-2014, 10:09 AM   #7
jmb6420
Engr. & Mechanic
jmb6420's Avatar
Dang, you never should have said that!
Mike
08 Rubicon Red Jeep Club #629
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline   Reply With Quote
