Replacing Factory Tires: Opinion Advice Needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Replacing Factory Tires: Opinion Advice Needed
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-21-2015, 11:26 AM   #1
plockyer
2010 JK Wrangler
Good morning,
I am due for new tires by the end of summer. My current tire size on my 2 Door Jeep Wrangler Sport is 255/75R17. A couple of questions:
1. What is the biggest tire I can put on factory 17's?
2. Do you have a recommendation? (Mine is stock, mostly highway driven... but I would like if possible agressive looking tires)
Thanks in advance for your help. Paul
plockyer is offline   Reply With Quote Quick reply to this message
Unread 07-21-2015, 12:22 PM   #2
yoyoyo109
2015 JK Wrangler
Do you have a lift? Without lifting at all you will have some rubbing issues with bigger tires. Using the Teraflex budget boost you could fit 33's with factory fenders while also using wheel spacers. That being said I do not suggest using spacers
95 YJ 4.0L 5spd AX-15
15 JKUR Hard Rock
yoyoyo109 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2015, 01:02 PM   #3
JoonHoss
2011 JK Wrangler
I read a GREAT comment here a few days ago, regarding tire recommendations...
Asking for a tire recommendation here is like asking someone to recommend a favorite color.
(I'd give credit to the original OP, but damned if I can remember who posted it first).
Hoss
"I'm a simple man. I like pretty, dark-haired women, and breakfast food."
JoonHoss is offline   Reply With Quote Quick reply to this message
Unread 07-21-2015, 01:17 PM   #4
YATZI1980
2011 JK Wrangler
Check the stickies at the top of page and FAQ. There are tons of threads on this good luck.
YATZI1980 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2015, 03:49 PM   #5
1222
Make mine a Jeep!
1222's Avatar
Dash mount for 2011-2015 JK’s
1222 is offline   Reply With Quote Quick reply to this message
