Replace Steering Coupling ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Replace Steering Coupling ?
Dual Color LED Light Bars White/AmberTJ 5.25" Speaker Adapters - NalinMFGAlloy USA Still Available
Unread 07-07-2014, 01:58 PM   #1
08JeepMan
2010 JK Wrangler
I have a consistent light "knocking" in my steering that I can feel as soon as I start rolling and just move the wheel left/right.... light knock or tap that you can feel.
The dealership says the steering coupling needs replaced ($300) Any thoughts?
I can't find a good description or parts to look up, nor can I find a good video. Any help is appreciated for a hopefully do it yourself job.
08JeepMan is offline   Reply With Quote
Unread 07-08-2014, 01:18 PM   #2
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
A 2013 should not be bad this soon, there are cases listed on this forum of the infamous coupling knock you speak of and most just used a grease gun and needle to fill up the boot with grease...those were the 07 and 08 years as I recall.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 07-08-2014, 02:00 PM   #3
motoguy1251
My 2012 with 85k miles on it has the clunk, I have not greased it yet, I'm just living with it.
motoguy1251 is offline   Reply With Quote
Unread 07-08-2014, 02:37 PM   #4
keycat02
2010 JK Wrangler
This worked for me: http://www.misch4x4.com/steering_cha...liminator.html
keycat02 is offline   Reply With Quote
Unread 07-08-2014, 02:46 PM   #5
Spank
Any reason why this isn't covered under warranty?
'12 Wrangler Unlimited Rubicon
Spank is offline   Reply With Quote
Unread 07-09-2014, 04:14 AM   #6
bogleparsons
Originally Posted by spank View Post
any reason why this isn't covered under warranty?
x2 ?
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline   Reply With Quote
Unread 07-09-2014, 05:59 AM   #7
08JeepMan
2010 JK Wrangler
Not covered because it's occurring on my 2010
Unread 07-09-2014, 02:52 PM   #8
jwmbishop
2011 JK Wrangler
That eliminator looks like it would work BUT - I have seen first hand what happens to a mans chest if the column does not collapse enough in a hard frontal impact and the box/frame and suspension deflection shoves the steering wheel into the cabin. I would not use it simply because I would not trust that the original design includes the possibility of such a modification in the amount force it takes to collapse it. Much like if someone was to soften the already soft detent in the GM ignition switch recall fiasco (or hang extra keys and do-dads on the ring)- making a problem worse - adding tension there could stiffen the column more than expected.
J Wm Bishop EA, ASADE
When I said that I was acceptably sane I may have exaggerated slightly.
jwmbishop is offline   Reply With Quote
