Removing steering wheel lock - JeepForum.com
post #1 of 9 Old 01-08-2007, 10:23 AM Thread Starter
kstar37
Is it easy to remove or disable the steering wheel lock on a 2007 Wrangler. I want to tow my JK behind my motorhome with the ignition key at OFF. I have an automatic transmission.
Thanks
Michel
Quebec City, PQ, Canada
2007 Wrangler Unlimited Sahara
4x4
kstar37 is offline
post #2 of 9 Old 01-08-2007, 01:44 PM
scottyc
Why not just tow it as described in the manual?
scottyc is offline
post #3 of 9 Old 01-08-2007, 03:18 PM Thread Starter
kstar37
Because of battery draw after hours of towing...when it's OFF, it's OFF!
Michel
4x4
kstar37 is offline
post #4 of 9 Old 01-08-2007, 04:01 PM
surfcaster
Why can't you just disconnect one of the battery cables?
surfcaster is offline
post #5 of 9 Old 01-08-2007, 04:56 PM Thread Starter
kstar37
No...I don't want that steering lock...Why a steering lock when there is none on the Grand Cherokee since 2005! Having to leave the ignition key in the ACC position (to keep the steering unlock) for towing behind a RV is really poor engineering design.
Michel
4x4
kstar37 is offline
post #6 of 9 Old 01-09-2007, 06:55 AM
Joec
Funny, mine's an automatic and it doesn't have a wheel lock.......... I thought that strange when I got it. (2007 Unlimited Rubicon)
2007 JK Unlimited Rubicon - Greystone, Auto, Power, Tow, Leather seats, Pneumatic Lumbar support, Seat Heat, GENTEX autodim mirror w/ map lights - temp - compass, AEM CAI, COOL TECH antenna mount, THULE Rack, CIBIE, Fuel Door, Grab Handles, Tuffy Trunk/Console/Overhead, Grill mod, Olympic Reversa bars,COOL TECH Magnaflow exhaust, Parking sensors,HESCO Supercharger
1972 C104 Commando - Stock
Joec is offline
post #7 of 9 Old 01-09-2007, 07:50 PM
Bigdog05
There should not be a battery draw when the steering wheel is just unlocked. Nothing is turned on. I tow mine all the time. I did get a spare key to unlock wheel, but will not run my Jeep.
Bigdog05 is offline
post #8 of 9 Old 01-09-2007, 10:43 PM
jdrogers
On the JK the first click on the ignition switch locks the steering wheel and is "accessory" power on. Things like the radio will work in this position. If you turn the radio off I suspect there is very little power draw. You could tow it all day without any dead battery issues.
Mine is an automatic and contrary to what the owners manual states there is a steering wheel lock! You can test this by removing the key and turning the wheel more than 1/2 turn.
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #9 of 9 Old 01-10-2007, 06:35 AM
Joec
Wow! There IS a lock! I stand corrected. I just had never turned my wheel that far after ignition off. How about that. I guess I wasn't curious or concerned enough about the (ahem, assumed) lack of a lock to investigate.......
Joec is offline
Steering Wheel Lock Roger Frazer JK Wrangler Technical Forum 3 01-06-2009 08:45 AM
05 LJ - No steering wheel lock? IWantMyMTZ TJ Wrangler Technical Forum 9 07-18-2008 06:10 AM
Steering Wheel Lock Roger Frazer JK Wrangler Technical Forum 12 10-09-2007 07:14 PM
Steering Wheel Lock Roger Frazer JK Wrangler Technical Forum 8 06-18-2007 06:59 PM
Removing the YJ steering wheel JeepersCreeper YJ Wrangler Technical Forum 3 06-21-2003 07:24 AM
