Removing rusted stripped exhaust bolts. - JeepForum.com
post #1 of 17 Old 07-21-2013, 11:37 AM Thread Starter
04WJfreedom
04WJfreedom's Avatar
Trying to install my exhaust spacer kit before the lift Goes on and the driver side exhaust bolts are so rusted and stripped I can't move them. They are in a very tight area to work in.
If I cut them how do I get the Threaded part of the bolt off that will still be stuck in there? Do I have to remove the exhaust to get these bolts off because I can't fit a drill in there to drill them? Here is a pic.
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
post #2 of 17 Old 07-21-2013, 12:13 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Hack saw, hot wrench and/or vise grips along with a good dose of PBlaster....
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 17 Old 07-21-2013, 12:18 PM Thread Starter
04WJfreedom
If I cut the bolt in the middle how do I get it out from there because the bolt will still be stuck In there. On the driver side there is very little room to work on the 2012 jk. I Barley got room to get a wrench in there?
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #4 of 17 Old 07-21-2013, 12:32 PM
SubAtomicGenius
2011 JK Wrangler
PB blaster or some other penetrant will work. Hacksaw, then soak for 1 hour in a liberal amount of penetrant, repeat if necessary. May need a little bit of prying or tapping or rotation with a set of vice grips, as Rocky said. Nice thing about waiting an our to soak, you can grab a beer in the meantime.
SubAtomicGenius is offline
post #5 of 17 Old 07-21-2013, 01:02 PM Thread Starter
04WJfreedom
So do you recommend I cut off the head of the bolt or cut it in the middle threaded part and work it out from there?
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #6 of 17 Old 07-21-2013, 01:11 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
It should be a bolt with a nut so if you cut in the middle both ends will just fall out or pull out easily. I don't think the bolt is threaded into the flange.
Jim
JLC08JK is offline
post #7 of 17 Old 07-21-2013, 01:18 PM Thread Starter
04WJfreedom
No there is a welded nut on the back of the Flange so if I cut in the middle im worried the threaded parts on both ends won't come out with how little room there is to get any kind of tool to the top bolt. I'm thinking I still won't be able to remove either end
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #8 of 17 Old 07-21-2013, 01:43 PM
Vin
When I was installing my spacers last week, the passenger side bolts both broke off. I just dremmeled them down level to the upper flange (with the welded bolt) then I just drilled them out using a small bit, increasing little by little until the left over section of bolt collapsed in on itself. With one hole, the bit went astray and damaged the threads a bit, so I just went to Home Depot, got a longer bolt and a nut and just fastened it that way.
Definitely try soaking them in PB Blaster first and letting them sit for a few hours (if you can over night).
Vin is offline
post #9 of 17 Old 07-21-2013, 01:44 PM
Filthy-Beast
Penetrating oil several times a day for a day or two, Liquid wrench works better than PB Blaster. If it breaks or you decide to cut it then these can help get the nub out.
http://www.amazon.com/Irwin-Industri...olt+extractors
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #10 of 17 Old 07-21-2013, 01:44 PM
Vin
If you cut in the middle, the pipes will come apart so you can move them out of the way enough to work on the stuck bolt. No worries.
Vin is offline
post #11 of 17 Old 07-21-2013, 02:17 PM Thread Starter
04WJfreedom
Thanks guys I've had them soaking with PB blaster for a few hours going to try removing them again.
If it doesn't work the ill have to buy an extractor. Because if I cut the top bolt there is still no room to remove the threaded part in that little space on the top bolt on the driver side. I removed the passages side no problem.
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #12 of 17 Old 07-21-2013, 02:25 PM
SubAtomicGenius
2011 JK Wrangler
Yeah, middle cut.
post #13 of 17 Old 07-21-2013, 04:38 PM
Vin
You can either undo the exhaust hangers to slide the pipes back, or if you can get the pipe to come out right after the Y, you should be good to go.
Vin is offline
post #14 of 17 Old 07-21-2013, 07:00 PM
jabsther
2010 JK Wrangler
Spay PB Blaster twice a day for the next week. Letting it soak in as the exhaust is heated up works great.
Did this on ZJ manifold bolts that were 12 years old with no problems.
jabsther is offline
post #15 of 17 Old 07-21-2013, 07:09 PM
Cropduster23
If you have access to AeroKroil made by Kano Laboratories, I'd suggest trying some of it as the penetrant. This stuff is expensive, but it will free up almost anything.
Cropduster23 is offline
