removing center console?? - JeepForum.com
post #1 of 6 Old 07-20-2011, 04:15 PM Thread Starter
monkers
2010 JK Wrangler
I tried searching and got no responses, I would like to know how to remove the center console from a 2010 2 door 6 speed. I want to make bushings to replace the dreaded plastic retainer for the transfer case shifter. Thanks
2010 Rescue Green 2 Door 6 Spd, 2.5" RK Max Travel, Fox 2.0 IFP Shocks, 37" Nitto Trail Grappler M/T, EVO Sleeves, Gussets, Mini Skids, Rock Stars, Poly Perf Long Travel Upper Shock Mounts, Poison Spyder Evap Skid, Diff Covers, Grab Handles, Cobra 75WXSt, Stern Cibie/Osram Light Upgrade, Mopar Heated Seats, Trimmed Flares & Bumpers
monkers is offline
post #2 of 6 Old 07-20-2011, 04:27 PM
Coppage
2009 JK Wrangler
Try reading the install instructions for the Tuffy security console. It may have clues on how to remove the oem console.
http://www.tuffyproducts.com/images/...st/157INST.pdf
Good Luck!
Coppage is offline
post #3 of 6 Old 07-20-2011, 05:19 PM Thread Starter
monkers
2010 JK Wrangler
Will do, thanks
monkers is offline
post #4 of 6 Old 07-20-2011, 07:35 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
sorry, misread.
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #5 of 6 Old 07-21-2011, 08:29 AM
MrOrange
2009 JK Wrangler
Tuffy's instructions have you disassemble the console. If you don't want to go through that trouble, the way I got mine off was to first remove the black panel that the cup holders is part of. You'll neeed to pull the parking brake as far as it will go. The panel is just snapped into place so give a tug here and there until you figure out where to pull. You can try starting with the top part that's snapped in just under the console lid. After that, pull the knob off the transfer case handle. It's also snapped into place but may need some force to pull off. After that, put the trasfer lever into neutral and remove the four screws on the lower sides of the console. You'll need to slide your chair back and forth to get to all of them. Then, it's all about getting around the stinking parking brake handle.
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
post #6 of 6 Old 07-21-2011, 11:07 AM Thread Starter
monkers
2010 JK Wrangler
thanks for the help
monkers is offline
Removing Center Console KrawlingT TJ Wrangler Technical Forum 4 06-28-2009 08:11 AM
Removing center console sykobozo TJ Wrangler Technical Forum 4 09-10-2006 11:07 PM
Removing center console tshiver TJ Wrangler Technical Forum 6 02-25-2004 07:13 PM
Removing the center console How? rshrimp TJ Wrangler Technical Forum 3 02-02-2004 06:35 PM
Removing '99 Center Console NCjeeps TJ Wrangler Technical Forum 14 01-15-2004 01:13 PM
