Removing 2011 JK Seats - Airbag Issues - JeepForum.com
post #1 of 27 Old 12-16-2010, 01:35 PM Thread Starter
rcullet
2011 JK Wrangler
I am having aftermarket seats installed today. The factory seats had supplemental airbags in them.
I would like to know if anyone knows for certain if the remaining airbags will function properly.
I would also like to know if there is a know solution for the airbag light that will inevitably come on once the factory seats are removed.
Thanks in advance for your help.
Rick
rcullet is offline
post #2 of 27 Old 12-16-2010, 01:56 PM
Ben_88Jeep
2010 JK Wrangler
Airbags IN the seats???? What for? Are they in the rear of the seats for the back passengers??? Never heard of that.... weird!
I would imagine you'd need to take it into your dealer to have the ECU reprogrammed to work without the additional airbags.
Ben_88Jeep is offline
post #3 of 27 Old 12-16-2010, 02:53 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
MANY cars have seat mounted side airbags in both the first and second rows.
To the OP...this is a great questions. If my understanding of airbags is accurate...they should all be wired independently of each other...as they each deploy in different scenarios...front impact, side impact, and severity of crash all determine which airbags deploy...
But this is just my take on the matter, I'm no pro.
Mol is offline
post #4 of 27 Old 12-16-2010, 06:55 PM
Vin
The side impact airbags are an option, so in that thinking they should be wired separately from the front airbags, so the computer will just see there are no more side airbags. I'm not a Jeep mechanic nor do I play one onTV and I didn't stay at a Holiday Inn, so you may want to contact Chrysler and verify.
Vin is offline
post #5 of 27 Old 12-16-2010, 07:00 PM
paul84043
Or just yank them out and let us know what happens....
Okay, NOT seriously...DON'T mess with airbags. Talk to a Mechanic first.
paul84043 is offline
post #6 of 27 Old 12-16-2010, 07:12 PM
HITMONEY
RubiKong's Trainer
HITMONEY's Avatar
I took mine out, the light is on but supposedly you can wire a resistor into the plug and fool the computer into thinking its there and no more light.
I Wheel a Wave Killer!
08 Unlimited RubiKong
Pics And Info Of My Junk
YouTube Channel
FaceBook
HITMONEY is offline
post #7 of 27 Old 12-16-2010, 07:18 PM
Vin
Why not take it back to the dealer and get it reflashed?
Vin is offline
post #8 of 27 Old 12-16-2010, 07:23 PM
teamgreen666
I know the air bag sensors are located under the front passenger seat but I didnt know they had air bags in the seats. Good luck with that one but lets us know what they say about that at the dealer....
teamgreen666 is offline
post #9 of 27 Old 12-16-2010, 07:58 PM
HITMONEY
RubiKong's Trainer
HITMONEY's Avatar
Cause they won't reflash something like that.
YouTube Channel
FaceBook
HITMONEY is offline
post #10 of 27 Old 12-16-2010, 08:03 PM
paul84043
Some of the new ones have side mounted AirBags.
Don't screw with them, AirBags are loaded with explosives and if messed with can be discharged by an errant static charge. (albeit a hefty one, do you really want to take the chance?) They're very dangerous...
I'm not even saying take it to the dealer, just talk to a qualified, reputable mechanic first....
post #11 of 27 Old 12-16-2010, 10:16 PM
Vin
Seriously? So they rather the computer think there is an airbag there and send a charge into your seat in the event of an accident?
Vin is offline
post #12 of 27 Old 12-16-2010, 10:49 PM
asknight
Technically, the dealer's hands are tied. Asking them to disable a safety feature installed by the manufacturer is bad juju. Why did you buy the side airbag option if you thought you'd ever remove/upgrade the seats?
And what "charge" are you talking about it sending into the seat. If you unplug the seat, remove it, and install an aftermarket seat the airbag service indicator light will come on, and there's no "charge" going anywhere near the seat. The propellant charge (if that's what you're referring to) is installed in the OEM seat, along with the airbag.
The only real problem here is if you have to have vehicle safety inspections in your state to get the vehicle licensed. You WILL NOT PASS INSPECTION if your airbag light is on.
asknight is offline
post #13 of 27 Old 12-16-2010, 11:35 PM
HITMONEY
RubiKong's Trainer
HITMONEY's Avatar
Its been an option on all JK's.
That is being a little dramatic..
Unplug the connectors under the seat, remove 4 bolts and the bolt holding the seat belt on and out comes the seat... sans explosion.
The dealer isn't going to re-flash ie down grade your saftey features... way to much liability involved in that.
Its not their problem that i removed my factory seats.
I wish mine didn't have the side air bags, but I had no choice.. I wanted the rig and it wasn't a deal breaker for me. A well placed .25 cent resistor will fix the problem.
Luckily, no inspections for me.
YouTube Channel
FaceBook
HITMONEY is offline
post #14 of 27 Old 12-17-2010, 12:40 AM
Warlord2
be sure and take some pics!
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #15 of 27 Old 12-17-2010, 12:54 AM
asknight
Carry on! You are on the right track and no one can fault you for the reasons you posted.
asknight is offline
air bag disconnect , air bag light , seats
Help removing entire dash (esp. pass airbag cover) beertinted TJ Wrangler Technical Forum 21 06-10-2010 08:06 PM
Are there any aftermarket seats that allow the use of the passenger side airbag? GotLime TJ Wrangler Technical Forum 13 08-27-2009 07:25 PM
What is the trick to removing airbag? Savvy JK Wrangler Technical Forum 5 06-16-2009 10:54 AM
Airbag Issues 91whiteYJ TJ Wrangler Technical Forum 3 04-26-2007 08:02 PM
bumper swap/airbag issues? mag162 TJ Wrangler Technical Forum 5 10-26-2006 01:56 PM
