Remove powdercoat from threads? - JeepForum.com
post #1 of 42 Old 10-09-2012, 09:26 PM Thread Starter
J33PNSL33P
Hey guys I just got my new jcr bumpers powder coated and on the front one they didn't mask the bolts completely. I can't get a single nut on. Is there an easy fix so I can put my bumper on? Or do I have to go back and deal with the shop that did the powder coating?
Thanks for the help
J33PNSL33P is offline
post #2 of 42 Old 10-09-2012, 09:36 PM
Doctor7474
Run it through the right sized die?
Doctor7474 is offline
post #3 of 42 Old 10-09-2012, 10:15 PM Thread Starter
J33PNSL33P
This is what I have the bolts are attached to the bumper and it looks like they didn't mask the ends of the bolt so I can't even start a nut
post #4 of 42 Old 10-09-2012, 10:42 PM
Coolcatracing
A die will cut that right off. If you take some sand paper it will knock enough down to get the nuts safely started but won't affect the metal.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #5 of 42 Old 10-10-2012, 01:12 AM
SubAtomicGenius
2011 JK Wrangler
Carefully chip it off with a hammer and a punch/screwdriver/chisel? Wire cup brush on a drill? 10 seconds tops, most likely it is a grade-8 bolt and it will be pretty hardy.
SubAtomicGenius is offline
post #6 of 42 Old 10-10-2012, 01:19 AM
1222
RIP John
1222's Avatar
I second using a stiff wire wheel on a drill.
(2011-2016)
1222 is offline
post #7 of 42 Old 10-10-2012, 07:05 AM Thread Starter
J33PNSL33P
All 16 bolts are covered and some will be very difficult to get at with any large abrasive without taking coating off the rest of the bumper. Ill call the shop today and see if they have an easy way to get it off before I attack it.
post #8 of 42 Old 10-10-2012, 07:10 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Just a cheap tap and a die set will give you what you need to chase threads. I wouldn't use the cheapoes to make new threads but they are great for chasing! I have two sets for that reason - one I bought at a tool flea market and one I bought in pieces from Fastenal.
If you have an extra nut you could cut into it with a cutoff wheel - slice it almost in half slightly off center - and use that.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #9 of 42 Old 10-10-2012, 09:12 AM Thread Starter
J33PNSL33P
The shop said the same thing. Either use a wire wheel on a dremel, or sand the excess and run a thread chaser up the bolt. I guess I'll be stopping off at the hardware store after work.
post #10 of 42 Old 10-10-2012, 10:15 AM
1222
RIP John
1222's Avatar
Nice of them to volunteer (offer) to do it for you since they screwed up on all 16 of them. I sure wouldn’t have anything powder coated by them again. I can see where maybe one of the bolts was missed being covered but every one of them, no way.
(2011-2016)
1222 is offline
post #11 of 42 Old 10-10-2012, 10:22 AM Thread Starter
J33PNSL33P
He said they leave the I ends if all the bolts because most people like the ends protected with powdercoat. But it filled the topmost threads in completely making starting a nut impossible. I was hoping they would volunteer but my experience with most things is u only want a third party touching it ONCE. If they clean the bolts off they will damage something else on the process. I would rather do it myself.
post #12 of 42 Old 10-10-2012, 10:39 AM
mike_baggly
That's a ridiculous statement covering for shoddy work.
mike_baggly is offline
post #13 of 42 Old 10-10-2012, 10:48 AM
1222
RIP John
1222's Avatar
I agree with you about doing it yourself versus someone who could care less about being careful with such a procedure. It’s just that if they would have at least offered to make things right it would have made you feel a bit better about what happened. Anyhow, if you ever have anything powder coated again that involves nuts, bolts or studs you can discuss your concerns with whomever beforehand and avoid a repeat.
By the way, I’ve been in the same situation as you but not to the extent that you’re having. Hope all goes well in cleaning up the threads.
(2011-2016)
1222 is offline
post #14 of 42 Old 10-10-2012, 10:51 AM
gwar11d2
2009 JK Wrangler
Nice. Let's see a photo of the whole bumper Which one did you get?
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #15 of 42 Old 10-10-2012, 11:23 AM
1AAdam
Originally Posted by 1222 View Post
i second using a stiff wire wheel on a drill.
x2
Adam
1aauto.com
888-844-3393
1AAdam is offline
