Remote Start - Engine Dies - JeepForum.com
post #1 of 9 Old 11-16-2013, 07:29 PM Thread Starter
webhannet
My 2008 JKU Sahara with factory remote start is working, but the engine dies soon after starting - the parking lights go out - the alarm light on the dash blinks.
Everything seems fine, but the check engine light has been one for a long time (O2 sensor, I'm told).
Would the check engine light cause the remote start to shut everything down? Winter's coming - that's when I use it.
webhannet is offline
post #2 of 9 Old 11-16-2013, 07:57 PM
VEGASROBBI
Yes many engine performance codes will allow it to start then die. With a door ajar it will not start at all.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #3 of 9 Old 11-17-2013, 01:00 AM
mello
What is your definition of soon? It will shut off after so many minutes and I believe it is ten minutes.
mello is offline
post #4 of 9 Old 11-17-2013, 09:36 AM
number40Fan
2014 JK Wrangler
The CEL will cause it to start and then shut off in about 5 seconds.
number40Fan is offline
post #5 of 9 Old 11-17-2013, 10:58 PM
RoubsX2
2010 JK Wrangler
Low fuel (fuel light on) also replicates the exact symptoms you describe which is normal for the system.
RoubsX2 is offline
post #6 of 9 Old 11-18-2013, 09:45 AM Thread Starter
webhannet
The five second seems about right.
I had my check engine light looked at (at an auto parts store - if that's worthwhile?), and they said it was an o2 sensor. The light HAD BEEN sporadic - I've been hoping for a time when the check engine light wasn't lit to test the theory, but it hasn't been happening.
I guess I may have to have the damn sensor fixed to find out.
Thanks for the answers!
post #7 of 9 Old 11-18-2013, 09:55 AM Thread Starter
webhannet
Just called dealer. There are four 02 sensors, and any one can cause the remote start to fail. I guess it will need to go in.
Thanks to all!
post #8 of 9 Old 11-18-2013, 12:16 PM
Woodchuck
Woodchuck's Avatar
If the check engine light is glowing, the remote start will not function. Well, it does, it does exactly as you say. Need to clear it and the remote start will function properly
'08 Red Rock Unlimited Rubicon / AEV 2.75" Lift with Remote Reservoir Shocks / AEV Heat Reduction Hood / AEV Front & Rear Bumper with Tire Carrier / AEV Skidplates & Rear Corner Guards / Riddler Diff Covers / Mopar Enhanced Rock Rails / Warn 9.5ti Winch / Mopar Gas Cap Cover / 4.88 Gears / IPF 900xs Drive Beams / Eagle Eye HID Spotlights / Daniel Stern Headlights / 17" AEV Pintler Wheels with 35x12.5r17 BFG Mud-Terrain KM2's / Tuffy Security Drawer / sPod and Benchmark Dual Battery System / Cobra 75 CB / Lockpick with Front and Rear Cameras / Katzkin Heated Seats / Line-X Interior / Hitchsafe Key Vault / and a Trasharoo and a lot more little stuff or just stuff I forgot!!!
____oooo
[ l_,[____],
l---L -[OlllllllO-
( )_) ( )_)-o-)_)
Woodchuck is offline
post #9 of 9 Old 11-20-2013, 09:40 PM
jfive
jfive's Avatar
What was the code? That should tell you which O2 to replace. Bank 1 or bank 2 sensor 1 or sensor 2.
Cheers,
John
'11 JKU
'88 YJ
jfive is offline
check engine light , remote start
