Remote Oil Filter? - JeepForum.com
post #1 of 2 Old 12-05-2010, 04:58 PM Thread Starter
perryhooah
Remote Oil Filter?
When I change my oil (2008 JK X Unltd) and pull the filter off, the oil in the filterruns out onto the axle. I have seen others (Toyota) that invert the filter so that the filter drains back into the engine. but at this point, I would deal with a 90-degree adapter so the filter holds the oil (not runnin all over the axle).
Am I behing the curve here or has anyone done this?
2008 UNLIMITED
OIF ('03-'04) & OEF ('07-'08)('12-'13) Veteran
perryhooah is offline
post #2 of 2 Old 12-05-2010, 06:08 PM
RAZORBILL
RAZORBILL's Avatar
2014 JK Wrangler
I wouldn't fuss with changing the filter orientation. I use a small tupperware bowl not much bigger than the filter to catch the oil when taking the filter off. After I get the filter off I let it run for a couple seconds then just stuff a paper towel over the filter area to catch any last drips. You can also put a plastic bag or baggie over the filter as you unscrew it to catch the oil.
Just my 2 cents on the subject...
Previously owned: 80 CJ-5, 97 TJ,99 XJ, 95 YJ,10 JK Rubicon Unlimited, 10 JK Sport
RAZORBILL is offline
anybody running Fox oem shocks w/ remote reservoir? RE Mono-Tube Shock W/ Remote Res? murzi3000 TJ Wrangler Technical Forum 2 10-04-2009 07:08 PM
how do i turn on my remote start/remote unlock? krany TJ Wrangler Technical Forum 18 12-17-2008 03:24 PM
Universal Remote B&M Transmission Filter akxj01 TJ Wrangler Technical Forum 5 09-23-2008 05:40 PM
Universal Remote B&M Transmission Filter akxj01 YJ Wrangler Technical Forum 1 09-23-2008 05:07 PM
Remote Oil filter and Cooler. KINGZ TJ Wrangler Technical Forum 14 06-06-2007 12:01 PM
