Regearing - Which parts to replace? - JeepForum.com
post #1 of 18 Old 11-26-2007, 12:21 PM Thread Starter
Meir10
Hi Guys,
I want to regear my X to 3.73. Rear axle is D44, Front is D30.
Do I need to replace the Carriers?
Meir10 is offline
post #2 of 18 Old 11-26-2007, 06:08 PM
tkob1060
2016 WK
no you dont need to change the carriers just to regear, they sell gears for your dana 30 and dana 44
tkob1060 is offline
post #3 of 18 Old 11-27-2007, 07:13 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
are you doing it yourself? if not, just have the shop buy the stuff they need. or tell you what manufacturer they use. more than one person has had problems with gears. installer says it's a bad gear set, manufacturer says it was a bad install....
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #4 of 18 Old 11-27-2007, 08:05 AM
Fishbulb
Fishbulb's Avatar
Does a person need special pullers to chage gears or do all the parts slide out after the axles or removed?
Male voice: For more enjoyment and greater efficiency, consumption is being standardized.
Fishbulb is offline
post #5 of 18 Old 11-27-2007, 10:13 AM
SecondTJ
SecondTJ's Avatar
Sounds like your not sure what your doing, I wouldn't touch the gears. If not set-up precisely they will be permanently damaged.
And yes, special tools are required to properly setup the gears.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #6 of 18 Old 11-27-2007, 12:16 PM
tx-Skydiver
tx-Skydiver's Avatar
1979 CJ5
x2
I can work on motors and pretty handy around alot of things on a vehicle, but I will not touch gears. Need special tools, guages to check clearances, etc... They are not complex, but you must be very precise which makes it difficult to get right for a novice.
Current Jeep:
2007 JK Wrangler Unlimited (Black), 4" SuperliftRanchoExpress Lift, 36" Super Swamper Irok's covering 16" ProComp's, AFE CAI, FlowMaster 40 Series, Shrockworks Rock Sliders, Rock Hard line of undercarriage skids, Warn Powerplant, Shrockworks Mid-width front bumper, Dana 44 Front
tx-Skydiver is offline
post #7 of 18 Old 11-27-2007, 05:56 PM
Fishbulb
Fishbulb's Avatar
I am not actually doing it. I am just curious how it works.
Fishbulb is offline
post #8 of 18 Old 11-27-2007, 06:25 PM
billycj7
order your gears from Northridge. Tell them what you are doing. Most likely all you need to order is the gears and an install kit. You do not need to order a rebuild kit with the new gears.
Vendors..... If you want to sell me a product, Spend more time developing it than I did earning the money to pay for it. I'm tired of overpriced Crap!
Moderators.......let people call crap crap, that way it means more when people say something is Quality
billycj7 is offline
post #9 of 18 Old 11-28-2007, 12:46 AM
SecondTJ
SecondTJ's Avatar
http://www.pirate4x4.com/articles/te...sta/Gear_Setup
SecondTJ is offline
post #10 of 18 Old 11-28-2007, 01:29 AM
HawaiiJeeperMC
3.73?
That is the lowest I have heard of anyone wanting to regear to... seems pretty low for the money that will be put into it. Just a thought, but you might want to consider something a bit taller if you are putting money into it.
08 Unlimited Rubicon.
04 Unlimited-sold
02 X-sold
98 Cherokee Classic, favorate vehicle I've ever owned-RIP
I'm thinking of a number between 2 and everything.
HawaiiJeeperMC is offline
post #11 of 18 Old 11-28-2007, 11:29 AM
SecondTJ
SecondTJ's Avatar
You mean that is a pretty high/tall gear for the money, and he should re-gear lower.
SecondTJ is offline
post #12 of 18 Old 11-28-2007, 01:23 PM
HawaiiJeeperMC
Yeah... I meant numerically low...
Thanks!
04 Unlimited-sold
02 X-sold
post #13 of 18 Old 11-28-2007, 04:08 PM Thread Starter
Meir10
I know that most people put 4.88 and more.
But I beleive thatfor me 3.73 would be enough for crawling and good for highway.
(Northbridge has only 4.88 and numerically high).
So If anyone changed from 3.21 to 3.73 and higher, I would like to know if a carrier has to be replaced, or just the Ring & Pinion.
Thanks
Meir10 is offline
post #14 of 18 Old 11-28-2007, 08:41 PM
Fishbulb
Fishbulb's Avatar
Nice link SecondTJ. Does a great job of explaining the intricacies. The way the curved teeth actually don't mesh all at once is one thing out of many within the link that I did not realize. It is in no way a job I would ever tackle now that I have read about it. To much consequence of error. I will stick to changing oil, belts, brakes and the like.
Fishbulb is offline
post #15 of 18 Old 11-28-2007, 09:51 PM
LHS-Cowboy
DETN8R
LHS-Cowboy's Avatar
I have been a technician for 18 years. 4 of them at a four wheel drive shop and I still have someone else do my gears.....
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power
Installed:
R.E. Modified 3.5 Super Flex Kit to 4+/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Heim Joint Adj. Trackbar/Rancho 9000XL shocks/Yukon 4.88 Gears & Superior Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Swing Away Carrier/...
____oooo
[ l_,[____],
l---L -[
OlllllllO]
( )_) ( )_)--)_)
LHS-Cowboy is offline
Regearing problem d44. Wrong parts? slafferty TJ Wrangler Technical Forum 11 01-15-2010 08:58 PM
Need to replace some parts. BEACHSAND TJ Wrangler Technical Forum 0 10-23-2008 03:31 PM
Parts list for regearing 30/35 3.07 to 4.11 beertinted TJ Wrangler Technical Forum 22 11-21-2006 05:57 PM
Parts Needed For Regearing D30? SteelBlueTJ TJ Wrangler Technical Forum 1 06-08-2006 09:29 AM
.::::: What parts for Regearing are the best ??! :::::. Tender_Heart TJ Wrangler Technical Forum 17 03-01-2006 01:09 PM
