Regearing to 4.10 - JeepForum.com
post #1 of 41 Old 05-16-2013, 12:54 PM Thread Starter
cyberpyrot
Regearing to 4.10
I hava a Sport S ant to regear to 4.10 what is everything I will need so it will go smoothly?
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #2 of 41 Old 05-16-2013, 12:56 PM
JoonHoss
2011 JK Wrangler
a checkbook or credit card....
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #3 of 41 Old 05-16-2013, 12:58 PM
dualtjs
2011 JK Wrangler
Most people would recommend 4.56, if you are going to regear an auto 5 speed. It works very well with 33's and is comfortable with 35's.
dualtjs is offline
post #4 of 41 Old 05-16-2013, 12:59 PM Thread Starter
cyberpyrot
Hoss
credit card
Thought of the day
post #5 of 41 Old 05-16-2013, 01:00 PM Thread Starter
cyberpyrot
what ever works for when I go to 35's
Thought of the day
post #6 of 41 Old 05-16-2013, 01:02 PM
HOKIES2010
2011 JK Wrangler
No matter the gear ratio the question almost looked like the OP is thinking of doing this himself. Please don't lol take it somewhere. Need to order the Ring and Pinion sets and the Master Install Kits and find a good shop and set aside a good chunk of money. The cost is why most people skip 4.10 if they didn't start there. AEV ProCal isn't a bad idea either to fix your settings.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #7 of 41 Old 05-16-2013, 01:06 PM Thread Starter
cyberpyrot
no way I was going to do it my self I just prefer to buy the parts want to knwo everything that will be needed just so the mechnic does not walk out with some strange device and say I need this and it will be $5,000
Thought of the day
post #8 of 41 Old 05-16-2013, 01:20 PM
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
I say go higher that the 4.10's as well. Do you know what gears you have now? If they are the stock 3.21's you will need a carrier for the front.
Here, this is our Yukon gear packages with Master install kits. Make sure you get the masters no matter what you do. They come with the bearings that need to be replaced as well.
http://www.krawloff-road.com/product_p/gearmaster.htm
That is everything for front and rear minus the carrier if you need it... and fluid!
-Jason
Phone: 864-437-8029
Forum Discount: KORJEEPFORUM
KrawlOff-Road is offline
post #9 of 41 Old 05-16-2013, 01:22 PM Thread Starter
cyberpyrot
-Jason
is tyhat front and rear? with carrier? What is nitros do I need that?
Thought of the day
post #10 of 41 Old 05-16-2013, 01:27 PM
LVCapo
2015 JK Wrangler
Heres the gear chart for the 2012. 4.10 would be perfect, if you were to stay at 33"s. Unless you plan on lots of rock crawling/serious offroading, going higher than 4.10 with 33's is going to leave you a little rough for highway travel. However, if you do plan on 35's, then the 4.56 is a option..
LVCapo is offline
post #11 of 41 Old 05-16-2013, 01:30 PM Thread Starter
cyberpyrot
im on 33's with 3.21's now I want to go 35's eventualy. I do notice is seams to not be as perky fron when it was stock I think adding all that iron may have made it a bit sluggish
Thought of the day
post #12 of 41 Old 05-16-2013, 01:33 PM
LVCapo
2015 JK Wrangler
If 35's is the goal, go the 4.56....it'll run at a higher rpm on the highway, but you'll get that uuumph back and do far less gear surfing under load.
LVCapo is offline
post #13 of 41 Old 05-16-2013, 01:36 PM
dualtjs
2011 JK Wrangler
-Jason
He has an auto, which is 3.73 geared. No carrier needed. Does your company have a list of "suggested" installers for different cities?
dualtjs is offline
post #14 of 41 Old 05-16-2013, 01:38 PM Thread Starter
cyberpyrot
I have an auto with 3.21 gears
Thought of the day
post #15 of 41 Old 05-16-2013, 01:40 PM
dualtjs
2011 JK Wrangler
Wow. When I was specking out new JK's, the jeep site automatically changed the gearing to 3.73, when I chose automatic.
I apologize for adding erroneous info to the discussion.
dualtjs is offline
