regearing for 33 inch tires - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > regearing for 33 inch tires
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting SleevesJeep Grand Cherokee Grills
Unread 09-06-2014, 07:57 AM   #1
jps444
2014 JK Wrangler
i've read in multiple threads that it's recommended to regear even if you are using 33 inch tires. but it's not a must if you don't mind the power loss. (still unsure if i want to regear actually and just live with the 33 inch tires and stock gears)
given that scenario, i'm currently in 33 inch tires (295/70/r17) and if i choose to regear for this set up then if in the future i upgrade to 35 inch tires do i need to regear again? or will the previous regearing will do?
jps444 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 08:33 AM   #2
pentastarguy
from your profile you have a rubicon, should have either 3:73 or 4:10 gears. should easily handle 33s with the diesel engine. what size tires are on their now?
pentastarguy is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 08:35 AM   #3
jps444
2014 JK Wrangler
got 33s on right now. 295/70/r17
so i can skip regearing confidently?
Unread 09-06-2014, 08:40 AM   #4
pentastarguy
yes, that was stock size, you could run 35s without issue. would just need speedo recalibrated. what gearing?
Unread 09-06-2014, 08:43 AM   #5
jps444
2014 JK Wrangler
i'm a big noob on the regearing aspect so i don't know.
so all i need to do is recalibrate my speedo?
another noob question when i lift to 2.5 inches that has no issues also in regearing right?
Unread 09-06-2014, 09:13 AM   #6
HAFICON
HAFICON's Avatar
FYI I ran 35 on 3.73s for a while had no problems in my 2012. I went to 4.88 only because I was doing lockers.. I love it but the RPMs are a little high. If you are only running 33s I would say keep it stock at least for a while see how it feels to you and go from there.
315/70/17 Duratrac on MB Wheels
AEV 2.5 with M.O.R.E 1" body lift
Viair 450c, ARB Air lockers,
4.88's and TNT truss.
My build thus far.
http://www.jeepforum.com/forum/f22/b...tures-1509366/
HAFICON is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 10:59 AM   #7
jps444
2014 JK Wrangler
happy to hear this! this makes me feel more comfortable running it stock on 33s! thanks so much!
Unread 09-06-2014, 11:10 AM   #8
zjilla
Waste of $$$
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 11:30 AM   #9
jps444
2014 JK Wrangler
Originally Posted by zjilla View Post
Waste of $$$
which one? regearing for 33s?
Unread 09-06-2014, 11:36 AM   #10
1222
Make mine a Jeep!
1222's Avatar
Like already said your stock gears are fine, no need to re-gear. To answer your other question, no, lifting does not affect gearing.
1222 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2014, 11:40 AM   #11
jps444
2014 JK Wrangler
thanks guys!
Unread 09-06-2014, 01:40 PM   #12
zjilla
Yes
