Recs for simple 2" spring lift, without shocks or bumps - JeepForum.com
post #1 of 4 Old 10-10-2009, 03:14 PM Thread Starter
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
Looking to lift less than 2" and use original shocks, bump stops. Most kits I see have the shocks and other add-ons. Can someone recommend a simple 1.5" to 2" set of springs? Will be going to 16 inch DC-1's with diameter of 33. Occasional off-road, but no hard-core. :P
09 Sahara 2 Door
Stock 18's/32
DocJake is offline
post #2 of 4 Old 10-10-2009, 03:23 PM
JKNorth
Here you go:
Daystar - Driven by Design
Simple spacers. Easiest way to go. Less than 2". If you're keeping mainly to the road, these should be just fine.
2008 Sahara Unlimited
33" DuraTrac's, 2" BDS spring lift, LOD Mid-width bumper, Rock Hard skid plates, Riddler diff covers, Rubi rock rails, Benchmark evap skid
JKNorth is offline
post #3 of 4 Old 10-10-2009, 04:27 PM Thread Starter
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
Thanks, JK. How do you like your BDS Spring lift? Did you change out your shocks as well?
DocJake is offline
post #4 of 4 Old 10-10-2009, 09:12 PM
JKNorth
I like it just fine! The ride is smooth, and it gave me enough lift to fit 33's comfortably. Plus, it comes with a lifetime warranty on parts, no questions asked, and it's made in the USA.
I replaced both springs and shocks. It also came with bumpstops, a trackbar relocation bracket and I fabbed up brake line extenders.
Of course, every now and then I want to go bigger. When I put the winch and bumper on, I'll pop in spacers in the front to bring it back up, and then some. Might throw some Daystar .75" spacers in the back too.
From what I've been able to determine you can get to 3" before you need to really start replacing a lot of suspension bits.
JKNorth is offline
Rear shocks are too long for the RC 2.5" spring lift. jgorm TJ Wrangler Technical Forum 369 03-08-2012 07:44 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
1 inch spring lift, new shocks? jeepsvo TJ Wrangler Technical Forum 1 05-16-2008 10:15 PM
leaf spring lift and shocks .. Cyclops YJ Wrangler Technical Forum 2 07-24-2005 03:26 PM
Simple "Simple Green" Question kaybone TJ Wrangler Technical Forum 2 12-08-2003 10:08 AM
