Rear wiper - JeepForum.com
post #1 of 9 Old 03-23-2014, 01:04 PM Thread Starter
rosana
Rear wiper
i just purchased 2007 wrangler X 2 door 4wd. no idea how to use the rear wiper. help? I looked on manual and i didn't find anything helpful. ALSO . U connect? how does that work? blue tooth on my phone doesn't connect to it? i checked MOPAR and no help there. THX
rosana is offline
post #2 of 9 Old 03-23-2014, 03:44 PM
folky27
The rear wiper is on the right stick coming off of the column. There's a small tab that you push forward. No idea about the U connect....
folky27 is offline
post #3 of 9 Old 03-23-2014, 07:09 PM
Jiblet
From the manual:
REAR WINDOW FEATURES — HARD TOP ONLY
Rear Window Wiper/Washer — If Equipped
A rotary ring switch on the control lever (located on the right side of the steering column), controls operation of the rear wiper/washer function. Rotating the center of the switch up to the “On” position will activate the wiper. Rotating the switch ring beyond the “On” or “Off” position will activate the rear washer. The wash pump will continue to operate as long as the lever or ring is engaged. Upon release, the wipers will cycle three times before returning to the set position.
If yours won't work, check to see that it was connected when the hardtop was installed. The connector is at the rear corner, driver's side, just inside the hardtop.
Jiblet is offline
post #4 of 9 Old 03-24-2014, 06:39 PM Thread Starter
rosana
AHH thanks guys! It turns out my lever doesn't look like that at rear wiper is just not connected to anything at all. found out it i have to purchase the lever like that one in the photo you posted which is about $100. weird how that happened. BUT THANKS FOR YOUR ADVICE/HELP
rosana is offline
post #5 of 9 Old 03-24-2014, 08:28 PM
ncb
Sounds like you need the Mopar kit to add the harness and controls for the hardtop
ncb is offline
post #6 of 9 Old 03-25-2014, 10:27 AM
Godholio
Yeah, sounds like your Jeep didn't come from the factory with the hardtop, it was added later (without the other parts to make the wiper work).
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #7 of 9 Old 03-25-2014, 11:50 AM
Jiblet
And I believe the computer needs then to be flashed to recognize the feature.
Jiblet is offline
post #8 of 9 Old 03-25-2014, 04:13 PM
ncb
This is true.
ncb is offline
post #9 of 9 Old 03-25-2014, 09:26 PM Thread Starter
rosana
thanks guys you've been much help!
-rosana
rosana is offline
2007 , jk , mopar , rear wiper , uconnect
