Rear track bar rubbing on springs, solutions? - JeepForum.com
post #1 of 4 Old 04-19-2009, 03:03 AM Thread Starter
Warlord2
Hey Ive had this problem after I corrected the pinion angle on the rear axle when I got the new driveshaft in. When I flex hard or go over a bump hard my rear springs will brush the rear track bar. Are there any adaptors I can buy that will move the track bar out a bit? Hasnt gave me any real problems, just some ginding noises while on the sand dunes. Its already an adj track bar so I didnt want to replace the whole thing and find I have the same problem with a different one. I cant be the first one to have this problem, what are some solutions?
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #2 of 4 Old 04-19-2009, 06:22 AM
Prot
Prot's Avatar
2014 JK Wrangler
Maybe going with a relocating bracket. Early designs were poor fir the JK but have since been improved. Based on my experience with poly performance high steer kit, I'd say give their rear bracket a try.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #3 of 4 Old 04-19-2009, 08:12 AM
edwin907
Check to see how your springs are sitting in the upper mounts.
I had the same problem and my spring was shifted to the rear of the mounting position.
Had to disconnect almost everything to get it loose enough to slide back over, but since that I'm good, no problems at all.
edwin907 is offline
post #4 of 4 Old 04-19-2009, 01:10 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
x2 - I had it unseat a bit during hard breaking, and had the EXACT same issue, but removing the spring and reseating it fixed the problem.
- Bill (formerly VetteDriver)
ChicagoGuy is offline
Changing from a 4" springs and rubbing wheel wells to a 6" springs (Will it help?) jdridin YJ Wrangler Technical Forum 9 06-19-2009 09:36 AM
rear track bar rubbing my gas tank skid? timritchieblue TJ Wrangler Technical Forum 6 12-22-2008 11:25 AM
Front track bar rubbing diff cover Xiled1 TJ Wrangler Technical Forum 7 09-09-2008 03:30 PM
Rear track bar rubbing tank skid chutta TJ Wrangler Technical Forum 2 04-02-2008 12:07 PM
Rubbing on springs.... z71offroader YJ Wrangler Technical Forum 15 06-03-2006 03:02 PM
