Rear Tow Hook - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Rear Tow Hook
New Knuckles Skid Plate at JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker Purcha
Unread 05-22-2009, 12:32 PM   #1
stuckmehere
2009 JK Wrangler
Rear Tow Hook
Newb here just wondering if anyone has a underside view of a installed rear tow hook on a newer 2 door JK. I saw one on a 4 door at the dealer and it was mounted on the back left under the bumper. Everything I have seen shows a 2 door mount in the middle of the bumper.
stuckmehere is offline   Reply With Quote
Unread 05-22-2009, 01:11 PM   #2
Rudinater
2009 JK Wrangler
I don't have a photo, but on the 09 at least you can put the hook in either place as there are bolt holes in each place. This way you have have a towing reciever and a recovery hook. My 09 Rubicon has the hook on the Left and I will have the towing receiver later.
On the 07's and 08's you got the hook or the towing package in the center, not sure if they have the mounting holes on the left or not.
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline   Reply With Quote
Unread 05-22-2009, 02:18 PM   #3
propped1
they dont have the holes but the rails run almost the length of the bumper. you could make a template and cut your own holes and use the tow hook assembly on the side and put the receiver inthe center.... just a thought.
its only six holes, but the rail closest to the bumper would require removing the skin to get to it.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline   Reply With Quote
Unread 05-22-2009, 02:31 PM   #4
b_c
check out my build thread...in the first 20 posts or so, i believe.
it's an 08, in the middle....the 09's moved theirs to the side to accommodate both the hitch and the hook. me personally, i don't like the hook off to just one side...
...leave too much possibility of strapping something off if you have to come from the other side.
Colorado JeepPeople
my 2008 jk build
greater love hath no man than this, that a man lay down his life for his friends -john 15:13
b_c is offline   Reply With Quote
Unread 05-22-2009, 02:41 PM   #5
elfamiglia
I have an '09 and from what I can see under the bumper, the left-sided hook is different from the middle one due to space. Of course you could buy the pre '09 and put it in the middle section of the '09 but the specific hook made for the left-side only won't fit in the center section. I have to visit my dealer to see if any of its Wrangler on the lot has tow hook.
Stuckmehere, wouldn't you mind hitting back the dealer to see how the hook looks on the underside?
elfamiglia is offline   Reply With Quote
Unread 05-22-2009, 03:40 PM   #6
stuckmehere
2009 JK Wrangler
Thanks for the responses. I think I would like to mount it on the left side and save the middle for a receiver later. The only difference I can remember when I was layed out in the stealership, was that the bracket on the left side was verticle and ran differently up the frame rail, not like b c who I saw had a three hole mount horizontally in the middle. I was trying to find a hook like da man (bc...after reading his mod's I'm in awe) on ebay or somewhere else so I would not be giving the dealer 70.00. The hook for the 09 Rubicon I think was a little different. Seems a little steep for one hook.
Unread 05-22-2009, 03:43 PM   #7
MacK
2010 JK Wrangler
I wouldn't mind two of those hooks, one on left and right. But I have a '07, would it fit?
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline   Reply With Quote
Unread 05-22-2009, 05:41 PM   #8
Tims034x44Fun
If you have the receiver already just buy an insert with a shackle in it. It'll cost you about the same, I think i saw it for $50 or $60. just my
Tims034x44Fun is offline   Reply With Quote
Unread 05-22-2009, 09:29 PM   #9
sparkiered
I got a hook on mine there are differant holes you line them up so they hit in center. You can watch in your area craigslist lot of peps get rid of them
sparkiered is offline   Reply With Quote
Unread 05-23-2009, 06:28 PM   #10
cyberpvnk
I'm getting rid of mine if you want it.
MyGIG REN for sale, works perfectly.
Looking for a 2DR JK softtop in good condition. Located in ILL.
cyberpvnk is offline   Reply With Quote
Unread 05-23-2009, 06:57 PM   #11
elfamiglia
Can't do it on the passenger side because of the exhaust pipe.
I posted somewhere here that I think the '09 side tow hook and mount has a shape of an 'I' while the middle one has a shape of a 'T." I came to this conclusion when I crawled under my bumper and see the mounting holes.
Unread 05-23-2009, 07:19 PM   #12
No_Return
A Receiver Shackle Starts around $25 - $45 and personally I feel they are better than a hook because the strap won't fall off the shackle like they can with a hook.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline   Reply With Quote
