Rear tire carrier removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Rear tire carrier removal
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-04-2014, 04:21 PM   #1
hub0619
2010 JK Wrangler
Have no idea if I'm putting this in the right place lol but I just took off my rear tire carrier on my jk and I put the bolts back in all the holes but how have u guys plugged up the hole left by the giant wiring plug and the huge rubber pieces that jut out lol here's a pic of what I mean
hub0619 is offline   Reply With Quote
Unread 03-04-2014, 04:22 PM   #2
hub0619
2010 JK Wrangler
Jesus Christ I can't spell
Unread 03-06-2014, 10:16 PM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to JK Forum since this question is JK specific.
Wheelin98TJ is offline   Reply With Quote
Unread 03-06-2014, 10:20 PM   #4
pmdowd6
Or use punctuation
pmdowd6 is offline   Reply With Quote
Unread 03-07-2014, 06:44 AM   #5
Lenny7
http://www.vectoroffroad.com/ufos-rear-p-56.html
or i'm sure cheaper things could be made or substituted, but it's an option.
Lenny7 is offline   Reply With Quote
Unread 03-07-2014, 06:49 AM   #6
1222
Make mine a Jeep!
1222's Avatar
fixed
JK Wrangler dash mount for Cellphones, GPS units, GoPro cameras, Spot devices etc.
1222 is offline   Reply With Quote
Unread 03-07-2014, 09:08 AM   #7
222Doc
well i went to napa and filled the holes with pop ins. one whole i used to bring the wires to the relocated plate/ third light mode. cost like 5 dollars. it aint bling but bling wont get you there.
http://parker4wheelers.tripod.com/index.html
http://www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote
Unread 03-07-2014, 09:26 AM   #8
1222
Make mine a Jeep!
1222's Avatar
Same here basically. I have an assortment of plastic ones that I bought from a local hardware store. They are low profile and just push in.
Unread 03-07-2014, 10:15 AM   #9
bogleparsons
do you guys just leave the vent the way it is or remove it too?
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline   Reply With Quote
Unread 03-07-2014, 10:40 AM   #10
RedRubiconLJ
RedRubiconLJ's Avatar
I left the tire bumps in the upper corners. The hole where the brake light wire came thru I bought a rubber valve cover grommet and stuck it in that hole. $3 at Oriellys. When I decide what to do with the other two rubber bumpers Ill pull them. They are a smaller hole as you know and Im trying to find another solid rubber grommet small enough for there.
2013 Black JKU Rubicon
PSC Brawler mid, Rockhard4x4 rear,
JCR skids, Riddler covers,
34" Toyo AT2's
Sold 2005 Red Rubi Unlimited
Jeep Pics
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline   Reply With Quote
Unread 03-07-2014, 10:55 AM   #11
1222
Make mine a Jeep!
1222's Avatar
I left the vent on; some remove it and put a plate in its place.
Unread 03-07-2014, 10:58 AM   #12
HighandLow
Stay Frosty...
HighandLow's Avatar
2010 JK Wrangler
Tramp Stamp
http://pix.poisonspyder.com/Products...9wH69&lb=1&s=A
HighandLow is offline   Reply With Quote
Unread 03-07-2014, 11:14 AM   #13
1222
Make mine a Jeep!
1222's Avatar
Originally Posted by HighandLow View Post
Tramp Stamp ...
Thanks. I was pretty sure thatís what it is called but not enough to call it that. Next time I wonít hesitate.
Unread 03-09-2014, 11:39 AM   #14
Gojo03
I made the plate out of aluminum. Grabbed some rubber plugs from the parts store for the holes.
Gojo03 is offline   Reply With Quote
Unread 03-09-2014, 03:24 PM   #15
HighandLow
Stay Frosty...
HighandLow's Avatar
2010 JK Wrangler
Looks good! Do you not run a license plate?
