Rear Differential okay? - JeepForum.com
post #1 of 12 Old 08-10-2013, 11:16 AM Thread Starter
orangera1n
2009 JK Wrangler
So I was wheeling in rim high mud and water and my friend was spotting me...
Lets just say he isn't the brightest guy. He thought I could make it across a tree stump under my carriage. Turns out it was a lot larger then he thought and my car bottomed out. I did not know I was bottomed out and thought I was just stuck in some mud and decided to switch into 4low and attempt to get out. My front tires dug down into the mud while the rear tires spun freely. After realizing my rear differential was stuck halfway on the stump we tried everything we could to get it out and managed to get the front of the car up to the door line in water (we had water leak in and all over my carpet ) Finally I relized the only way to get out was to winch out. The only problem was half my winch was submerged and water and electricity don't go good together not to mention it would probably ruin my winch. After hooking up about 500+ feet of cable and toe straps I was able to drag the jeep the rest of the way off the tree stump. My winch did make some grinding noises but it seems fine now. I inspected the differential and it appears to have zero damage. Is this normal? It was dragged about a foot and a half over the log and hit it at about 5mph. Do you guys think there will be any long term damage?
orangera1n is offline
post #2 of 12 Old 08-10-2013, 11:35 AM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
Probably not any damage at all. Check your oil though, (front and rear) to make sure you didn't get any water or mud in your diff.
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #3 of 12 Old 08-10-2013, 11:42 AM
Filthy-Beast
Yeah, it's probably fine. Mud + spotter you should already be in 4-lo.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #4 of 12 Old 08-10-2013, 12:05 PM
allibaster
I wouldn't worry at all. Differentials usually see a lot of action when off-roading.
I'd highly recommend getting some solid differential covers, though. The factory ones have a tendency for the outside lip to bend and provide little protection for your gears. Best armor you can get in my opinion.
'13 JKU 10th Anniversary
allibaster is offline
post #5 of 12 Old 08-10-2013, 03:40 PM Thread Starter
orangera1n
2009 JK Wrangler
Thanks for the advice guys.
I think ill be buying some new jeep armor soon
And when I pulled the jeep off the stump it took half of the stump with it lol. Wish I had pictures!
post #6 of 12 Old 08-10-2013, 04:09 PM
ncb
I'd hate to see what 500+ feet of cable and straps do when it breaks.
ncb is offline
post #7 of 12 Old 08-10-2013, 04:23 PM
brianjw
What kind if cheapo winch are you running?
brianjw is offline
post #8 of 12 Old 08-10-2013, 04:24 PM
gunshw301
It would probably snap the bs train it came on square in half!
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #9 of 12 Old 08-10-2013, 04:25 PM Thread Starter
orangera1n
2009 JK Wrangler
I didn't have my synthetic cable on ether...
My friend actually cut his hand pretty bad when he was connecting the line to a tree.
The max amount of line I've used before is about 800ish feet. A friend had his truck stuck out pretty far in some deep mud. We ended up mixing tow straps, chains, nylon rope, and winch wire to get him out.
post #10 of 12 Old 08-10-2013, 08:48 PM Thread Starter
orangera1n
2009 JK Wrangler
Smithybuilt xcr 8
post #11 of 12 Old 08-11-2013, 05:15 AM
bogleparsons
I've actually used my Superwinch almost completely under water.
Didn't want to, but she worked.
(check those Diff's!)
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #12 of 12 Old 08-11-2013, 07:54 AM Thread Starter
orangera1n
2009 JK Wrangler
I think you have a small leak...
jeep , rear differential , stuck
