Rear D44 Spare Axle Shaft, Carry One or Two? - JeepForum.com
post #1 of 3 Old 06-11-2013, 03:35 PM Thread Starter
cvd
cvd's Avatar
I donít normally carry spare axle shafts, as I have them at base camp in the RV. However for an upcoming 1,000 mile non-RV trip, I need to pack spare(s). There is about 1 1/4Ē difference in the driver vs. passenger side shaft length (I think the driver side is shorter). If I carry just the shorter shaft, can it be used on either side? If needed (i.e. I bend or brake a shaft), it would need to get me off the trail and a couple hundred miles home.
cvd is offline
post #2 of 3 Old 06-11-2013, 07:42 PM
HappyTrails
HappyTrails's Avatar
I believe the shorter side is the right side. I doubt that you can swap one side for the other. Easier to carry both, than find out the hard way when you need them.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #3 of 3 Old 06-11-2013, 10:52 PM Thread Starter
cvd
cvd's Avatar
IIRC the TJ D44 was about 1/2" difference in the axleshaft lengths; meaning you could carry just the shorter shaft for a trailspare. I was surprised to find the JKD44 shafts at 1 1/4" difference. Unless someone tells me they’ve successfully done it, I’ll have to carryspares for both sides.
cvd is offline
