rear axle shaft removal? - JeepForum.com
post #1 of 10 Old 02-11-2011, 10:45 PM Thread Starter
Warlord2
I cant get my axle shaft freed up, all the bolts are out and the e-brake assembly is loose but I cant break the axle free. Any ideas on how I can pull this shaft out? hard to pry out with the ebrake in the way and have already tried wacking the hell out of it with a hammer. There isnt a C clip or anything inside the pumpkin to hold them in right?
My axle got bent and was destroying my bearings, wondering if thats why its not easy to pull.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #2 of 10 Old 02-11-2011, 10:56 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
It sounds like the bend is creating a bind at the carrier.
Try rotating the axle as you pound on it from behind the flange.
If that doesn't work you will probably have to loosen the caps on the carrier bearings and turn the shaft until the pressure is relieved.
Good luck
Jim
JLC08JK is offline
post #3 of 10 Old 02-11-2011, 11:17 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Once you remove the 4 axle plate bolts it should slide out with the bearing assembly - agree, the bent axle is probably jammed into the carrier and will need some force to get it out - no C clips I am aware of in the JK D44 rear. JKC08JK is right, you may need to pop the diff open and loosen the bearing caps to get some play and wiggle it out of the carrier.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 10 Old 02-12-2011, 12:09 AM Thread Starter
Warlord2
thanks guys! after nobody said there were C clips I got a little bit rougher with it and managed to use a pry bar on it. It popped right out and I was able to slide the new chromos in just stuck on getting these damn ebrake cables back on now.
Warlord2 is offline
post #5 of 10 Old 02-12-2011, 12:16 AM
JLC08JK
JLC08JK's Avatar
Please try not to make it sound so difficult
I'm going to tear my whole rear-end down tomorrow and I need all the confidence I can muster just to get started
Gears, locker, shafts, truss, and brackets are all on the list
Jim
JLC08JK is offline
post #6 of 10 Old 02-12-2011, 12:30 AM Thread Starter
Warlord2
man I swear it would be a peace of cake if these damn ebrake cables would go back on.
Warlord2 is offline
post #7 of 10 Old 02-12-2011, 12:42 AM
ronjenx
ronjenx's Avatar
Did you pin the e-brake handle/drum in the cab?
If not, you need to go and do that.
It holds the spring loaded drum so the cables will be extended.
ronjenx is offline
post #8 of 10 Old 02-12-2011, 12:43 AM
JLC08JK
JLC08JK's Avatar
Just zip-tie 'em up to the frame, they won't stop you in a real emergency anyways!
They should be called "only for parking on level ground brakes"
Jim
JLC08JK is offline
post #9 of 10 Old 02-12-2011, 04:32 PM
RockyClymer
RedRock4Wheeler
Opps, the instructions call for you to lock the ebrake cable prior to removal just to avoid that, they are self adjusting and you will need a spoon or such to back them off. Thought you had the manual?
NRA Life member
post #10 of 10 Old 02-12-2011, 04:51 PM
ronjenx
ronjenx's Avatar
The cables will bee too short to reconnect (at the wheel) if the drum on the lever in the cab is not pinned to the lever, with the lever all the way down.
ronjenx is offline
Dana 44 axle shaft removal merdas TJ Wrangler Technical Forum 15 09-06-2016 04:26 PM
Rear axle shaft removal question...pics inside samger2 TJ Wrangler Technical Forum 43 05-05-2010 07:25 PM
D44 Rear Axle Shaft removal??? Mino TJ Wrangler Technical Forum 3 04-10-2009 12:05 PM
axle shaft removal archie YJ Wrangler Technical Forum 5 09-12-2006 07:45 PM
Dana 30 Axle Shaft Removal? pyro9862 YJ Wrangler Technical Forum 11 04-19-2006 07:38 PM
