Rear Axle Kits. Superior vs. Ten? - JeepForum.com
post #1 of 21 Old 06-03-2012, 10:40 AM Thread Starter
Mol
Disclaimer: I'm Polish
Mol's Avatar
The Superiors clearly advertise their lifetime warranty, and have been in the game a long time. I can find them at a $100 advantage to the Tens.
The Tens supposedly have an "EXCLUSIVE" torque equalizing diameter profile that allows the short side of the axle to have the same ductility as the longs side. Fluff? The Tens also have rolled splines, vs. the cut splines of the Superiors...again, I don't know if this is really all that importantm, given the lifetime warranty of the Superior, and the fact that the OE 32 spline axles withstood every bit of offroad abuse I have thrown at them (it took a Nissan Versa t-boning me to finally bend them).
Anybody have a take on the matter, or am I reading into this too much?
Mol is offline
post #2 of 21 Old 06-03-2012, 10:41 AM Thread Starter
Mol
Mol's Avatar
Pics...both kits include bearings, seals, and studs (tens studs are press in, Superiors are thread-in)
Mol is offline
post #3 of 21 Old 06-03-2012, 11:12 AM
SubAtomicGenius
2011 JK Wrangler
Rolled splines are forged, so all that material in the grooves is actually forced into the root and or tooth section of the axle shaft spline. A cut spline is machined and the material is simply removed to form the teeth. Hence, in theory, rolled splines are stronger. This isn't that big of a deal, because both shafts are made of chromoly steel (4130) and they're much stronger than stock shafts anyhow. Most times an axle shaft actually breaks mid-way instead of at the spline - in theory supposed to save your more expensive parts from self-destructing.
Looking at the pictures, I'm not sure what those large holes are on the hub of the Superior shafts - I'll have to read about the purpose of that! At a glance, I'm not too sure if I'm fussy about that material being taken away from one side of the hub for balance purposes...
Regardless, I think either way you'll win.
Interested to see what you finally get!
SubAtomicGenius is offline
post #4 of 21 Old 06-03-2012, 11:17 AM Thread Starter
Mol
Mol's Avatar
Thanks, makes perfect sense I think you're right: six in one hand, half-dozen in the other.
Being that we don't have an account with Ten, and the Superiors retail for $100 less, I'll probably order the Superiors for the substantially better deal.
Mol is offline
post #5 of 21 Old 06-03-2012, 12:29 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
superior EVO series are better product. superiors axle shafts are made in the states with USA steel and feature better metallurgy and heat treating than their brethren. Superior makes 2 series of their axle shafts. Replacement and EVO. their EVO's are their premium product. that said - i ran 10 factory shafts in my TJ and they were great.
the large hole in the superior shaft is an access hole so you can remove the bolts that hold the axle shaft retainer plate to the axle. all D44 axles have them as they are semi-float. the 10-factories in the above picture are for a Dana 35, see the little nub at the end of the splines? its for a C-clip.
My builds:
and
or follow us on
spyder6 is offline
post #6 of 21 Old 06-03-2012, 12:40 PM Thread Starter
Mol
Mol's Avatar
Good info - I hadn't noticed two different lines of the Superior shafts, I'll look closer and order accordingly.
Is there an obvious reason why the 44 cannot be converted to a full-floater?
No kidding? That's the pic they use for their 32 spline 44 shafts
Mol is offline
post #7 of 21 Old 06-03-2012, 12:45 PM Thread Starter
Mol
Mol's Avatar
Found the Evo kits - cold formed, rolled splines just like the Ten axles.
Edit: The only rubi-compatible Evolution Series kits are for the front. The only rear Evo is a Dana 35 set for the rear
http://www.jeep4x4center.com/jeep-axle-differential-parts/alloy-usa-superior/jeep-wrangler-jk.htm
Mol is offline
post #8 of 21 Old 06-03-2012, 01:41 PM
spyder6
spyder6's Avatar
2010
to get the EVO series for the rear can only be obtained as a Super 44 kit, 35 spline.
a full float conversion wouldn't be cost effective for a D44. thats something you look at for 1 Ton trucks. plus i don't think they ever made a full float 44
My builds:
and
or follow us on
spyder6 is offline
post #9 of 21 Old 06-03-2012, 02:01 PM Thread Starter
Mol
Mol's Avatar
I got it figured out...
It's 32-spline according to Superior's website, part # EV52
But it can be upgraded for $30 from 32 spline rubicon shaft to 35 spline without having to go to a super 44 kit (if you dont need locker, etc.)
Warn used to make them, but that was years ago. I have come across a few XJs and TJs that still have them.
Mol is offline
post #10 of 21 Old 06-03-2012, 02:18 PM
SoK66
2009 JK Wrangler
I've been running Superior Evolutions front & rear for two years and so far all's been good. Biggest complaint is that Superior is often on what somone called "Intergallactic Backorder". The first set of fronts I had were so off center they hit the inner sleeves. Took them a month to get me a set that were properly on center. Worth checking into or you may have a long wait. OTOH, the rears pressed together fine and have taken a beating, no problemo.
SoK66 is offline
post #11 of 21 Old 06-03-2012, 02:19 PM
spyder6
spyder6's Avatar
2010
i was mistaken. but like i said - superiors EVO stuff is the best you can get
My builds:
and
or follow us on
spyder6 is offline
post #12 of 21 Old 06-03-2012, 02:21 PM Thread Starter
Mol
Mol's Avatar
Cool - sorry, not trying to pull a "ha, you were wrong", just tryingto make sure I'm ordering the right stuff the first time
Mol is offline
post #13 of 21 Old 06-03-2012, 02:25 PM
jrmars07
2010 JK Wrangler
Your problem:
Wait I'm at least 1/4 Polish too damn...
2010 2dr Wrangler
2.5" ProComp Lift, Front Adj Trackbar, JKS Disco's
Fox Shocks
Tera Front Lower Controls Arms, Rear Upper Control Arms, Synergy HD Balljoints
Tom Woods 1310 Driveshafts
33" KM2's on ProComp 7069 16x8's
Superchips Flashpaq
AEV Premium Front Bumper, IPF 900XSD Lights, Warn 9.5ti w/ Synthetic Line
AEV Rear Bumper, Tuffy Security Deck
D30 Front Sleeved and Gusseted, RCV's, ARB Locked
4.88 G2 Gears
D44 Rear ARB Locked, Chromoly Shafts
jrmars07 is offline
post #14 of 21 Old 06-03-2012, 02:32 PM Thread Starter
Mol
Mol's Avatar
Originally Posted by jrmars07 View Post
Your problem:
The ginger is hurting you more than the pole
Mol is offline
post #15 of 21 Old 06-03-2012, 04:05 PM
SubAtomicGenius
2011 JK Wrangler
Great info, Spyder6 - thanks. So I suppose that it is the Superiors, then Molshove?
Superior Axle's new axle Super Truss kit installed, beef up your axle for only $399 Jerry Bransford TJ Wrangler Technical Forum 164 01-09-2015 12:14 PM
Rear Axle Bracket Kits Harvo TJ Wrangler Technical Forum 2 08-10-2010 09:40 PM
Super 35 kits: Yukon or Superior? mcneil TJ Wrangler Technical Forum 28 11-03-2008 12:41 PM
Best Price on rear Axle bracket kits? pwcracer TJ Wrangler Technical Forum 15 06-19-2008 10:52 AM
Dana 44 Rear Axle Bracket Kits Rickster TJ Wrangler Technical Forum 1 02-23-2006 06:01 PM
