Really..how long to fold the soft top down? - JeepForum.com
post #1 of 19 Old 04-07-2007, 04:18 PM Thread Starter
tbrkek
Ok..so really, how long does it take you all to fold the soft top back? I finally got mine on after my fingers were almost takin off! They are still numb! Anyway I didn't even attempt to fold it down, because it was just a pain to get it installed. I would think with taking off the rear windows it would take a good 20 minutes or so. Does the rear window actually have to be taken off or just the sides? Also, what are you're preferred methods? Do you start from the middle or the front and unhook from there? Thanks!!
tbrkek is offline
post #2 of 19 Old 04-07-2007, 04:21 PM
4GvnSnr
5-10 minutes maybe... Only had it down 3 times so far... I unhook the front latches, take the side windows out, then the rear and the rest is cake from there.
4GvnSnr is offline
post #3 of 19 Old 04-07-2007, 04:52 PM
infosponge
infosponge's Avatar
It gets easier every time you do it and as the top gets broken in.
infosponge is offline
post #4 of 19 Old 04-07-2007, 04:54 PM
KrasnayaZnamya
KrasnayaZnamya's Avatar
10 minutes max, and I'm taking my time as it's new. It's been off four times so far and it seems a lot easier than my TJ.
KrasnayaZnamya is offline
post #5 of 19 Old 04-07-2007, 05:07 PM
Dypuz
Dypuz's Avatar
10 Min is pushing it. As long as you know what velcro and zippers look like, you should be good.
But seriosly, it just does not take that long. Try doing the windows first. If you leave the windows on, you will scratch and scuff them. If you keep them in the back, I suggest fold them evenly once or try a window roll. I don't know how the roll works with the JK windows since they don't seem to roll very well, but if you try it, let the rest of us know how you do(and post pics). Good luck. Wait until you have to put the top up when an unexpected down pour begins. That kind of rain creates record times.
Dypuz is offline
post #6 of 19 Old 04-07-2007, 05:28 PM Thread Starter
tbrkek
Well...better than I was hoping for!! Thanks for the replies! As far as unhooking the sides around the Jeep, do you start from the middle or doesn't really matter. Just seems really tough to unhook 'em. Although, I guess someone said it gets easeir, so maybe they have to be broken in a little. Thanks again guys..and Happy Easter & Passover to all!
tbrkek is offline
post #7 of 19 Old 04-07-2007, 06:16 PM
trips
Do you mean the little plastic flaps that attach the windows to the body? If so, I think its easiest to start at the ends. Although, after you unzip the window they just slide right out anyway. As far as the rear window goes I just roll it up into those straps that they give you at the dealership.
It won't be long before you can do it with your eyes closed.
'07 X
auto, 4.10
255/75R17
trips is offline
post #8 of 19 Old 04-07-2007, 06:23 PM Thread Starter
tbrkek
No...not the plastic flaps that attach the windows. Those plastic flaps that basically hold the soft top attached to the body. They sort of flip under the edge around the Jeep. It was pretty tough to get those in, and I thought I once saw someone said you have to start in the middle of the jeep, then work you're way forward, then go back to the middle, and head back. I thought I saw that, but maybe not.
tbrkek is offline
post #9 of 19 Old 04-07-2007, 08:27 PM
tx-Skydiver
tx-Skydiver's Avatar
1979 CJ5
...and be careful putting it back up. I ripped one of the straps right out of the rivots on the horizontal bar. Now I have to pop them out and use metal screws to resecure. It hasn't caused any ill effects though. It still drives the same and sounds fine. Not really sure what they are for anyway. I guess to not have so much stress on the top when taking on and off? Oh well.
Current Jeep:
2007 JK Wrangler Unlimited (Black), 4" SuperliftRanchoExpress Lift, 36" Super Swamper Irok's covering 16" ProComp's, AFE CAI, FlowMaster 40 Series, Shrockworks Rock Sliders, Rock Hard line of undercarriage skids, Warn Powerplant, Shrockworks Mid-width front bumper, Dana 44 Front
tx-Skydiver is offline
post #10 of 19 Old 04-07-2007, 10:02 PM
BJeepJK
If it was cold/chilly out when you put your top on the fabric would be hard to stretch. On a nice day, in the 70's, it's easy to get those plasic strips out of the channel. Start behind the front doors and move towards the front then from behind the front doors, go towards the rear.
BJeepJK is offline
post #11 of 19 Old 04-07-2007, 10:14 PM
RedRockJK
1987 YJ Wrangler
Originally Posted by tx-Skydiver
...and be careful putting it back up. I ripped one of the straps right out of the rivots on the horizontal bar...
My strap on the passenger side pulled loose from it's rivets as well. I'm taking mine in Monday to get them to warranty it. It didn't rip loose or anything, the strap just came loose from the rivets.
RedRockJK is offline
post #12 of 19 Old 04-07-2007, 10:49 PM
Dypuz
Dypuz's Avatar
I don't think I have this right. Do you have a 4dr or 2dr? Because with the 2 dr, once you get the windows off, it dosn't matter which direction you go. Plus, I gotta agree with BJeepJK. You sound like you know what you're talking about with the 4dr. Also good point about the temp.
Dypuz is offline
post #13 of 19 Old 04-07-2007, 11:11 PM
Dypuz
Dypuz's Avatar
Just found a pic of your rig. Nice. Good luck with the 4dr. I'm no help to you with that top.
Dypuz is offline
post #14 of 19 Old 04-08-2007, 09:34 AM Thread Starter
tbrkek
That's what I thought I heard and exactly what I was looking for. Thanks!! And yes, it was about 45 degrees when I took the hard top off and put on the soft top, so hopefully you are right and it'll be easier in warmer air. Thanks!!
tbrkek is offline
post #15 of 19 Old 04-08-2007, 10:23 AM
CyBerAliEn
It is a lot EASIER when it is warmer. The top expands enough to make it very easy. I took my top off after it was sitting in 85 degree sun for hours... the top almost felt so soft; it was really easy to remove and put back on. If you wait until its in the 70s or such; it should be very easy!
And it gets easier the more you do it. The first ~3 times, it took me ~10 mins+. But after that, I can do it in a good 5 mins or so at a moderate pace.
Of course, I have a 2 door. I think it would prob take another min or so if I had a 4-door.
-Andrew-
....2007 Jeep Wrangler X (JK), 2-door, Silver
........Oh so many 4-doors!
CyBerAliEn is offline
does the soft top fold? 92yjwrangler YJ Wrangler Technical Forum 6 09-12-2009 09:15 PM
How to fold soft top? Jakked TJ Wrangler Technical Forum 3 08-27-2006 12:57 PM
Soft Top fold down (Like TJ's) AWILD YJ Wrangler Technical Forum 2 05-09-2004 02:30 PM
Soft Top Fold Down Questions... Stiffler YJ Wrangler Technical Forum 2 03-27-2004 08:01 PM
soft top fold down xxxdwilson TJ Wrangler Technical Forum 12 06-19-2002 12:56 PM
