Real thoughts on body lift - Page 7 - JeepForum.com
post #91 of 127 Old 03-10-2013, 09:36 AM
mrchips59
I dont like body lifts, period
mrchips59 is offline
post #92 of 127 Old 03-10-2013, 09:53 AM
SLADE
i can't figure out if you're bad at math or you simply don't understand this concept. I'm inclined to believe the later.
If you install a 3" lift, with 2" bumpstop extension, you have gained 1" of uptravel....and provided you use longer travel shocks, you've gained more travel total. That's the whole point of a lift.
Again, your looking at the suspension as a number and not the physical location.
you gain 1" of uptravel with 3" lift + 2" bumpstops. such as 4" to 5". That's not too shabby.
Not too shabby, but when you look at being able to double the amount of compression you gain... Thats a Huge gain. If your looking at only gaining 1" compared to 2" thats a loss.
maybe, maybe not. I've heard that before. Plenty of manufacturers claim that on TJs, yet it's not anywhere near accurate. I've got a pile of parts in my garage that were supposed to fit with my lift too, yet didn't. When I help a friend install a bunch of parts on his JK, we'll see if his components of choice actually fit as advertised.
Know whats in your lift and what it requires.
like I said, then your tires are too big. Run 33s or 34s instead. The difference off-road won't be earth shattering. or modify the body/tub/fenders/etc to fit.
You can run 33's on a stock JK.... why would you put a 3" lift on a JK only to run 33's just because your shock only requires a 1" bump stop? A 35" tire requires 17.5" of clearance from the body at full compression regardless of your lift height. To get that clearance, you have to extend the bump stop, Trim/flat fender, add a bump stop, OR a combination.
Not everyone wants to start cutting the body or flares.
The AEV 4.5" kit doesn't even come with longer shocks than the 3.5" kit, It comes with shock "extensions" (you know that little male/female piece that screwes onto the top of the shock). How much longer than stock are the AEV Bilstiens for a 3.5" lift? Where is the gain in travel when a shock extension is used?
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #93 of 127 Old 03-10-2013, 10:12 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you've said this multiple times now, but failed to illustrate what this means.
the axle moves away from ride height, and the uptravel/downtravel around that are whats important.
I'm well aware of what my suspension does, because i've pushed the axle to every position possible...full bump, full flex, full droop, with the springs removed....anytime you install a lift, whether it's JK, TJ, ZJ, whatever, you should do the same thing...
lift isn't about tire size, it's about gaining travel.
then do it.
then don't.
but as with all things, a compromise has to be struck someplace.
funny, I run home made shock extensions on my Jeep The gain is in the downtravel. If you require bumpstop extensions, in which you lose some shock uptravel, then you can relocate the mounts. Shock extensions would be one example of relocating the shock mounts....making the shock's fully compressed length the same as the bumpstop extension requirement, so you regain that lost uptravel back as downtravel. This way you don't have to physically cut/weld/relocate the lower or upper shocks mounts to allow for a longer length shock.
Is it ideal? meh, not really. but then again, neither is your anti-squat anymore. it's all a compromise.
and uptravel is only half this equation...you still need downtravel. keeping a reasonable travel ratio is also important.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #94 of 127 Old 03-10-2013, 10:42 AM
SLADE
You've only failed to understand. Forget about your numbers and go look at your suspension.
I have. It's probly why I understand how everything can work together instead of by itself. It's Why I can see the waste in alot of lift "kits".
While technically your correct.... It's not the top priority for most.
Just look through the titles of the threads on this forum. Do you think your going to find more that refer to wanting to run XX" tire size, or wanting to gain X" of suspension travel? Take this thread for example, The OP doesn't want to gain X" of suspension travel, he wants to run a 35" tire and have 3.5" of lift.
So you have room for a longer shock with more travel (that big number you like to focus on), but instead your running shocks that are shorter than what fits your needs.
Explain to me how you gained down travel if your shock travel remained the same? Wouldnt that be the same thing as losing uptravel with a bump stop? You would have gained travel by using a longer shock. You lost travel in your shock because of the bump stop.
Wouldn't you "gain" even more droop if you ran a shock that is the right length? You have room for a longer shock, but your not taking advantage of it.
By the sound of it, you had more bump stop than you needed for your shock, so you put an extension on your shock instead of using a shock that is the proper length for your suspension.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #95 of 127 Old 03-10-2013, 10:47 AM
OregonVette
Ps... Wrangler boy, when these JKs first came out (look at old threads from 2006 to 2008) nearly all of us had 2.5" BB lifts & 1.5" spacers.
It works well for 32"-35" tires, increases off road capabilities, inexpensive & keeps the original handling characteristics (drivelines, Control arms, gearing, suspension etc).
Certainly, " the next level" such as lifts 3" or more look great, have much better off road capability, bigger tires etc. but... As we all know, aside from a handful of well known/ famous rigs on this site, the majority of all these Jeeps are still daily drivers. 95% of their existence is on the road. But, when they do go in the dirt, we demand top-notch off road experiences.
Personally, we drive our JKU hundreds/ thousands of miles to get we're we're going. Go to MOAB, we drive. Go do a backcountry discovery route, we drive. Go to the eastern deserts, we drive. Since we don't trailer our rigs, the journey itself is equally as important as the destination. So, for many, having a giant JK on a 6" lift, buying 37" tires at $500 a pop each, getting 6 mpg with 5:88 gearing, new LA kit, new axles, new drivelines etc just doesn't make much sense at all.
It really depends on how you use the rig.
A 2.5" BB (especially a complete kit from a quality vendor) makes this a possibility for not much money.
Ps... I too used my teraflex shock extensions for 4 years (until the factory shook mount grommet finally warped).
If anything... Most guys have wished they bought an OME 2" kit from the get-go. I might even be in that group too.
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #96 of 127 Old 03-10-2013, 11:30 AM
Unlimited04
Let's say a 13.5" compressed length shock fits in the stock location, without bumpstop extension. Let's use a 10" travel shock, so the extended length is 23.5". Now, you determine you need 1" of bumpstop extension to keep something else from smashing together. Now you've essentially got a 9" travel shock...because you can't use that 1" you've bumpstopped out. However, if you install a 1" shock extension, you essentially make the new compressed length 14.5" and the new extended length 24.5". So you've regained the 1" of lost travel back as downtravel.
not really, because if you need 1" bumpstop extension to keep stuff from smashing together, you can't use that extra 1" shock uptravel anyway. that's why you can add it back into downtravel, either by using a shock with a different compressed length (like 14.5"), or by using a shock extension (to effectively give 14.5").
not if the shock travel is the same. if you have a 10" travel shock, it doesn't matter if the compressed length is 14.5" or 13.5+1" due to a shock extension, the travel will still be the same.
I added enough bumpstop extension to avoid major suspension interference & clearance issues, then modified the shock mounts to utilize full stroke of the shock.
Useful Write-Ups:
Funny:
post #97 of 127 Old 03-10-2013, 03:04 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
Unlimited, you will not win this argument. Just let this guy think what he wants and let this thing die.
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #98 of 127 Old 03-10-2013, 04:02 PM
SLADE
Why wouldn't you use a shock that has a 1" longer collapsed length (which would also have a longer stroke), and actually gain travel?....
Point being. If the bump stop is there because of lack of tire clearance, a Body lift may allow that bump stop to be removed. Removing that 1" bump stop adds 1" to the suspension travel (instead of just moving the range lower on the scale). If the bump stop is not there for tire clearance, adding one will not effect the suspension.
Adding an extension doesn't turn it into a shock with a colapsed length of 14.5", it turns it into a 13.5" shock that takes up the same amount of space as a 14.5" shock. Your not getting the travel that a 14.5" shock can have. Saying a shock extension turns it into a 14.5" shock is like saying a bump stop doesn't take away from the suspension travel.
So your claining that a shock with a collapsed length of 14.5" won't have any more travel than a 13.5" travel shock.
It's allready been argued that suspension lifts allow for more travel because they make room for a longer shock to be ran (that how you get that bigger number that you like).... Why in the hell would you not take advantage of the new found room for a longer shock and moe travel?
You can "what if" and "not if" all you want. This shows your obvious lack of concern for waste when it comes to suspension travel.
Well then a body lift won't allow you to remove any bump stop now will it.... I don't think I've claimed that a Body lift will allow you clearance for your suspension components...
So you have room for a longer shock with more stroke (a longer stroke), but you chose not to limit your suspension with a shock that is shorter than what you can actually run.
It's obvious we see things fom two different sides.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #99 of 127 Old 03-10-2013, 06:47 PM
DoctorTim
holy crap, just shut the **** up slade...
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #100 of 127 Old 03-10-2013, 06:52 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
It is useless to have a battle of wits with an unarmed person. Quit feeding this troll...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #101 of 127 Old 03-10-2013, 06:57 PM
Unlimited04
if you want to give me a few hundred bucks for new shocks, I may be able to find a suitable set.
if not, I guess I'll just have to use the 2" lift shocks I've got, with a modified mount.
or since the JK's don't really have any major benefits to BL's, like a gas tank tuck, tummy tuck or MML, why not just add that needed clearance into the suspension with a little more lift and appropriate shocks/bumpstops? or modify/change the fenders?
hmm, so I can have a 13.5" compressed length shock, with 9" travel, use a 1" bumpstop extension to reduce it to an 8" travel shock....or I can move the shock mount, and get that full 9" stroke, which includes 1" more downtravel than the previous option.
Perfectly ideal? probably not. Will it work? you bet.
Similarly, you can go the opposite direction...move the shock mounts further apart, and run an even longer shock.
You're talking yourself in self satisfying circles.
If your bumpstop extensions take away suspension travel, then obviously you should leave your Jeep totally stock....because if you lift it or add bigger tires, you're going to need add those evil bumpstop extensions.
that's going to depend on brand and how the shock is designed.
I take advantage of all the shock travel in my suspension, and that's always what I recommend to other folks as well.
wow, you obviously have never read much of what I talk about over in the TJ forum.
Yet you've been telling me I should run less bumpstop because I need more uptravel?
I choose not to limit my suspension. I choose to run a shock with a suitable stroke length & compressed length, possessing good valving for a nice ride, which fits within the shock mounts I have.
Useful Write-Ups:
Funny:
post #102 of 127 Old 03-10-2013, 07:02 PM
SLADE
You've had nothing inteligent to add since you started participating. At least Unlimited04 has some inteligence to offer.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #103 of 127 Old 03-10-2013, 07:25 PM
SLADE
Thats your comprimise/sacrifice.
A JK may not have as many benifits as a TJ, but there are still benifits.
Or you could run a 14.5" shock (compressed length) and have 10" of travel...
Not really. Just killing time talking about Jeeps. I'm not having a blind conversation.
If your bumpstop extensions take away suspension travel, then you should leave your Jeep stock....because if you lift it or add bigger tires, you're going to need add those evil bumpstop extensions.
I thought you said you shouldn't add bump stops just for tire clearance...
Thats where the Body lift works with your suspension.... When you need tire clearance....
You should compare shock length and how the compressed length compares to overall travel. you can compare shock lengths within a brand and from brand to brand.
It's safe to say that the longer the compressed length, the longer the stroke/travel.
Yes there are exceptions.
I'm sure you have a sufficient amount, but you've allready admitted that there is unused travel because of lack of funds for a longer travel shock.
I've read alot of what many people have said on all kinds of forums.... What makes your posts worth stalking?
Ive only stated that a Body lift will add tire clearance without reducing suspension compression/uptravel travel.
Ive also recomended using the most shock you can fit for the required bump stop.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #104 of 127 Old 03-10-2013, 07:45 PM
Unlimited04
same as the high anti-squat I get running short arms, even with a 2" lift.
so what benefits exist, other than tire clearance?
no, not really, because there aren't any good 14.5" compressed length 10" travel shocks for my application. Your choices are basically either 13-13.5" or 15.5-16" area (spec'd at 0-2" lift, and 4").
like I said before, it's last on the list.
So you're saying, the body lift is better than adding the necessary clearance into the suspension instead?
Not really, here's a good example.
For my 2" lift, the spec'd Bilstein shocks are 8" travel, 13"-21". The Old Man Emu shocks I have now are 9" travel, 13.5-22.5".
Similarly, in the JK, a Bilstein shock for 2" lift (24-146708) has less travel than the Old Man Emu shock for the same application (60066). The Bilstein has is a ~9.5" travel (15"-24.5") and the Old Man Emu is a ~10.5" travel (15"-25.5"), about an inch longer.
So for the same amount of bumpstop extension and a similar shock body size, you get an inch more travel out of the OME's.
So yes, there are exceptions all over the place....in other words, you're better off paying attention to brands and compressed/extended lengths.
what? As I already pointed out, I've got zero unused travel. In fact, my shocks are 1" longer than most and I have MORE travel than most.
well...obviously you aren't interested in learning.
oh, so now you're agreeing with me?
Useful Write-Ups:
Funny:
post #105 of 127 Old 03-10-2013, 07:50 PM
DoctorTim
A fool is made more of a fool, when their mouth is more open than their mind.
2012 , 35's , aev , body lift , high steer
