Re-gearing question - JeepForum.com
post #1 of 13 Old 03-19-2012, 09:15 PM Thread Starter
pikegulley
2011 JK Wrangler
Re-gearing question
So, I'm getting 2011 6-speed re-geared this week to 4.88 (I'm rolling on 35" BFG KM2). A group I'm riding with is doing a run this weekend up near Tahoe. I was curious if I should still go on the snow run after getting re-geared? I've read some stuff about breaking in the gears. I was wanting some opinions.
pikegulley is offline
post #2 of 13 Old 03-19-2012, 09:27 PM
ronjenx
ronjenx's Avatar
They should be broken in before you load them up with a snow run.
They need to have time to lap in, including some easy 4wd for the front gears.
ronjenx is offline
post #3 of 13 Old 03-19-2012, 10:21 PM
joe002
You can see all kinds of opinions from “yeah break them in” to, “drive it like you stole it”.
I broke mine in - as recommended by Yukon.
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #4 of 13 Old 03-20-2012, 02:01 AM Thread Starter
pikegulley
2011 JK Wrangler
The guy installing said I should probably do about 500 miles of off and on driving to break them in. Does that sound right?
2011 Black Rubicon "Rubi"
3.5" Rubicon Express Short Super Flex - 35" BFG KM2 - 4.88 gears - 1.5" Spidertrax wheel spacers - XRC front and rear bumpers - XRC 8 winch - Bushwacker Trail Armor - Bushwacker Flat Fenders
post #5 of 13 Old 03-20-2012, 06:51 AM
ronjenx
ronjenx's Avatar
Yes. Off and on to let them cool. You should include some 4wd to lap in the fronts, since you will be wheeling in snow later on.
You can google breaking in gears if you want to read the whole routine.
ronjenx is offline
post #6 of 13 Old 03-20-2012, 08:58 AM Thread Starter
pikegulley
2011 JK Wrangler
Thanks for the advice!
post #7 of 13 Old 03-20-2012, 08:03 PM
joe002
Good advise.
joe002 is offline
post #8 of 13 Old 04-02-2012, 11:52 AM Thread Starter
pikegulley
2011 JK Wrangler
So, the gears are in. I have some questions that I haven't really been able to get straight answers for. I was assuming that after I got the gears put in I would be able to see somewhat of an increase in my MPG. I wasn't expecting anything dramatic but it is looking like it has got worse (<12 mpg). This is probably due to the way I'm driving and terrain, I'm not sure. The power is back which is nice! Would love to know how people with a similar setup are getting better MPG.
I am curious as to where I should be keeping my RPMs when I'm going through the gears. I mean, I've drove a standard all my life but never really paid attention to my rpm. I always shift when it feels right. But now, since I'm trying to optimize my mpg the best I can, anything advice would be great.
The other question is, do i need to recalibrate my speedometer and the computer to compensate for the gear change and tires? I thought that I would need to but the guy at the shop said that it will be near stock again so I would not need to do so, "it will even out".
Opinions?
post #9 of 13 Old 04-02-2012, 12:23 PM
tslewisz
2010 JK Wrangler
If you haven't recalibrated you have no idea what miles per gallon you're getting because you don't know how many miles you've driven.
tslewisz is offline
post #10 of 13 Old 04-02-2012, 12:28 PM Thread Starter
pikegulley
2011 JK Wrangler
So, I do need to recalibrate regardless of what he said? Plus, was I eye balling my gas gauge on a route that I commonly drove before and after.
post #11 of 13 Old 04-02-2012, 01:02 PM
ronjenx
ronjenx's Avatar
The guy who said it would even out is only partially correct: Performance wise, yes; Speedometer/odometer wise, no, he is not correct. You need to recalibrate for the tire size. The speed/distance data is taken directly from tire rotations.
Where you have a 6 speed, you don't need to recal for the gears, but you might as well do it while you are in there.
ronjenx is offline
post #12 of 13 Old 04-02-2012, 01:24 PM Thread Starter
pikegulley
2011 JK Wrangler
Thank you!
Any input on the RPM ranges I should be keeping while driving?
post #13 of 13 Old 04-02-2012, 01:37 PM
ronjenx
ronjenx's Avatar
Thank you!
I can't advise you on the 6 speed, as I have an automatic.
On mine, though, I do what it takes to generally keep the rpm around 2,000.
I'm not afraid to have it higher, but I don't like it to be much lower when there is a demand for power on the hills.
ronjenx is offline
4.88 , break in , gears , manual , mpg
Gearing question... pfifer TJ Wrangler Technical Forum 9 01-07-2010 06:14 PM
gearing question bigdog79 TJ Wrangler Technical Forum 12 02-23-2008 07:19 PM
Gearing Question Cwill15 TJ Wrangler Technical Forum 7 01-22-2008 04:47 PM
Question on gearing red92YJ YJ Wrangler Technical Forum 8 04-07-2007 01:17 PM
Yes, another gearing question spurrimj TJ Wrangler Technical Forum 3 07-28-2005 05:58 PM
