Re gear question, 2012 Rubicon - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Re gear question, 2012 Rubicon
Savvy Billet LED Tail LightsLight up the holidays with LED lights from JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-01-2014, 09:33 PM   #1
Our_Rubi
Im considering a 2012 JK unlimited Rubicon, it has a lot done to it including 37" tires but it has not been re geared. My local Jeep dealer told me late model 12's and newer could not be re geared because of ECM (or some other electronic device ) won't communicate properly once the gears are swapped. Any truth to this? Thanks.
Our_Rubi is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 10:08 PM   #2
LVCapo
The Voice of Reason
LVCapo's Avatar
No, they are idiots...do not let those clowns touch your jeep.
LVCapo is online now   Reply With Quote Quick reply to this message
Unread 11-01-2014, 10:18 PM   #3
Our_Rubi
I was chatting with the sales person on the lot, he told me they tried re gearing a 2013 to accommodate a customer when they accidentally sold him a Jeep that couldn't tow what they promised. I was told the Jeep wouldn't shift out of first gear.
Unread 11-01-2014, 10:38 PM   #4
Spank
They obviously didn't do it right. Search around. Plenty of people in 12's running 4.56's and 4.88's. The gear swap and a simple setting adjustment with a ProCal or whatever works just fine.
'12 Wrangler Unlimited Rubicon
Spank is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 11:18 PM   #5
mrwhipple
I'm running 4:56 gears on an '12 for 35s. Runs great and no issues. You'll need a Procal to reset the computer for the new gearing and tire size. $150
4:88s are perfect for 37s.
silver jkur
mrwhipple is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 08:07 AM   #6
Our_Rubi
I won this jeep on ebay last night and Im not sure if I should go to 35"s or re gear, sounds like either size tire the re gearing would be a good idea. Im thinking the jeep may look funny w 35"s since the fenders are so small.
http://www.ebay.com/itm/2012-Unlimit...vip=true&rt=nc
Unread 11-02-2014, 09:22 AM   #7
HemiJK37s
2011 JK Wrangler
a 2012 Ruby will have a 3.73 or an optional 4.10. 2012 was the first year that 4.10 was an option and not a standard in a Ruby. The 3.73 and a 37 would work, a 4.10 would be ideal. any taller gear than a 4.10 would be necessary if you live in a steep hill or mountain area or do a lot of rigorous off roading or tow a heavy load on a regular basis.
we have a 2012 and a 2013 in the family one with a 3.73. and one with a 4.10. Don't let people convince you that a 4.10 is not tall enough as they are basing it on the punch off the line and not what the tachometer being in the eco range is saying as that is what you base the engines performance on.
HemiJK37s is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 09:31 AM   #8
HemiJK37s
2011 JK Wrangler
if it has 3.73's and I didn't like the way it performed I would remove the body lift and run 35's. if 4.10's I would drive it as is and enjoy. I do not think you have to re-gear as you are in the ball park. either option is a lot cheaper than re-gearing and many many jeeps are running much worse tire to gear ration scenarios. thats a nice rig, enjoy it
It does not have leather seats as stated in the description fyi!! No heated seats or side airbags either just a note.
Unread 11-02-2014, 01:56 PM   #9
Our_Rubi
I was built with the 4:10 ratio, I thought removing the body lift and going 35" would be the best option. I live in Central Florida so only a few hills but nothing to steep. I'll drive it as is for now, still have to wait a week or so for transporter to bring her home.
Unread 11-02-2014, 02:37 PM   #10
HemiJK37s
2011 JK Wrangler
I live in SOFL and have same set up and its perfect. Enjoy it!!
