RC 3.25 vs 3.75 , some questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > RC 3.25 vs 3.75 , some questions
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueStainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 04-06-2014, 07:54 AM   #1
chaznad
I know this has been discussed but I've searching for days and can't find a straight answer . I have an 07 sahara unlimited.
I was looking to pull the trigger on the RC 3.25 but i read that i will need a SYE/ driveshaft which is definitely not the route i want to take $ wise ,, then again hundreds of people have 3.5 plus of suspension with no need for an SYE . I was told 4" plus then you need longer driveshafts and what not
Id rather not lift the body , but if it'll save me a grand then sure.. This is simply for road use, 35" tires and minor trails 1-2 x a month
Also do both of these kits level out the front and rear or would i need to get some front spacers
thanks in advance
97 TJ 4.0 , 3spd Auto , D30/44 , 3.25 RC lift w/ 1.25" BL / MML , ( 5 )33x12.50x15 Goodyear Duratracs
“Too many people spend money they haven't earned, to buy things they don't want, to impress people they don't like.”
chaznad is online now   Reply With Quote
Unread 04-06-2014, 08:56 AM   #2
ROCKR8R
JKs don't need sye but drive shaft, at 3.5-4" is when you'll want a front one at least on the unlimited. A 2.5" lift can get you to 35's without the need for drive lines. I would consider new gear ratio, though.
-Dan
ROCKR8R is offline   Reply With Quote
Unread 04-06-2014, 09:00 AM   #3
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
IMO, I would be more concerned about rear drive shaft than front. Reason, the front is a high pinion differential and can tolerate a higher lift with less offset and it only runs under load when in 4wd. The rear, esp on a two door, has a greater angular offset and would benefit from a double cardan joint DS...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 04-06-2014, 01:39 PM   #4
ROCKR8R
Right. The rear went out on my 2 door before the front. However, he is a 4 door. The rear driveshaft on the unlimited is longer so it is more forgiving at 3.25-3.5"
-Dan
Unread 04-06-2014, 02:17 PM   #5
SubAtomicGenius
Sarcastic Fantastic
SubAtomicGenius's Avatar
2011 JK Wrangler
Personally, I'd opt for the RC 0" lift or get a 3" quality brand.
SubAtomicGenius is offline   Reply With Quote
