Radio not as loud when top is off - Page 4 - JeepForum.com
post #46 of 117 Old 06-05-2013, 05:42 PM
jrmars07
2010 JK Wrangler
This baffles me. I still don't know what to think of it. Still waiting on a few more confirmations before I get the will to do this.
2010 2dr Wrangler
2.5" ProComp Lift, Front Adj Trackbar, JKS Disco's
Fox Shocks
Tera Front Lower Controls Arms, Rear Upper Control Arms, Synergy HD Balljoints
Tom Woods 1310 Driveshafts
33" KM2's on ProComp 7069 16x8's
Superchips Flashpaq
AEV Premium Front Bumper, IPF 900XSD Lights, Warn 9.5ti w/ Synthetic Line
AEV Rear Bumper, Tuffy Security Deck
D30 Front Sleeved and Gusseted, RCV's, ARB Locked
4.88 G2 Gears
D44 Rear ARB Locked, Chromoly Shafts
jrmars07 is offline
post #47 of 117 Old 06-05-2013, 06:17 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Don't drink the kool aid if there's a difference, its negligible at best.
Mol is offline
post #48 of 117 Old 06-05-2013, 06:30 PM
panthermark
Forget making a jumper wire, simply use a fuse. Someone on the WF came up with that idea and it worked. Scroll through that WF thread and you will see pics. I posted some myself.
Jeep - It's a Jeep thing...you wouldn't understand.
Triumph - Go your own way.
I see why I'm a loner....and I love it!
panthermark is offline
post #49 of 117 Old 06-05-2013, 06:50 PM
Wavedatya
2010 JK Wrangler
Ok so let me get this straight.
Hard top on quieter?
Hard top of louder?
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #50 of 117 Old 06-05-2013, 07:19 PM
TheBoss
Hard top of louder?
Somebody needs to go to the 1st page before they post , silly :-D
TheBoss is offline
post #51 of 117 Old 06-06-2013, 06:10 AM
panthermark
Just bend the prongs about 45 degrees on a fuse and use that as a jumper.
This is mine:
post #52 of 117 Old 06-06-2013, 09:28 AM
buckeyedolfan
2015 KL Cherokee
I was taking off my hardtop on my 2013 JKU with the radio on and unplugged the harness and yup the radio volume and bass got softer for sure. Time for the fuse trick i guess.
buckeyedolfan is offline
post #53 of 117 Old 06-06-2013, 09:29 AM
buckeyedolfan
2015 KL Cherokee
Its noticeable for sure,especially the bass.
post #54 of 117 Old 06-06-2013, 09:40 AM
buckeyedolfan
2015 KL Cherokee
Just did the fuse trick and all good now. Back to the loudness
post #55 of 117 Old 06-19-2013, 05:37 AM
Wavedatya
2010 JK Wrangler
Ok. Ok. JTphoto can you post a write up or some more pics?
Also, if the comp notices the hard top is disconnected and turns the radio down does it also stop the rear washer fluid hose from squirting if the knob is turned? And will this trick make the jeep think the hard top is on? Or is it for radio?
My head hurts
post #56 of 117 Old 06-19-2013, 07:36 AM
JTPhoto
JTPhoto's Avatar
My head hurts
Just look a couple posts above you see the photo of the fuse pushed into hardtop harness plug. It just bridges between the purple/white stripe wire and the black... You can use a wire jumper or twist the blades slightly on a micro fuse so they line up with terminals in the plug..
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #57 of 117 Old 06-20-2013, 08:12 PM
Jeepin It
Jeepin It's Avatar
This is mine:
I am going to try this in the morning.
Chris
2012 JKU Sahara
RIP
2004 TJ Sahara
RIP
1992 YJ Renegade.
Jeepin It is offline
post #58 of 117 Old 06-21-2013, 09:19 AM Thread Starter
REPPO
Here's my work around. It does make a difference.
REPPO is offline
post #59 of 117 Old 06-21-2013, 10:29 AM
Cooneys08JK
Cooneys08JK's Avatar
Just did the fuse trick. I connected it a few times to see if there was a difference and there is. I have the stock unit with the infinity system and you can really tell once the volume is up past 24.
This was one of the quicker "mods" to date.
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline
post #60 of 117 Old 06-21-2013, 12:04 PM
Jgjg76
Well this might explain why my stereo seemed to have lost some oomph since Spring. I just figured the softop was a lot louder so I had to turn it up higher.
Jgjg76 is offline
