Quicker Disconnects - JeepForum.com
post #1 of 3 Old 08-10-2010, 07:26 AM Thread Starter
Res6cue
2009 JK Wrangler
Quicker Disconnects
After putting on the 2" lift, it was recommended that I lengthen the Sway bar links (hope my terminology is right still a newbie). I was told to use the JKS Quick Disconnects. Here is a link to what I have found.
Quicker Disconnects by JKS
Please let me know your thoughts or suggestions or .
Thanks,
Mike
Res6cue is offline
post #2 of 3 Old 08-10-2010, 07:58 AM
frankie945
Those are what I'm runnin. They are great. Real easy to disconnect.
say yes to JKOwners.com just say no to jk-forum
frankie945 is offline
post #3 of 3 Old 08-10-2010, 08:15 AM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
most people that run the JKS quick discos love them.
i never got them because it only takes a second to remove my Rock Krawler swaybar disconnect.
since i have to wait for the air down on the tires, its a perfect time to disconnect them and move on.
Rock Krawler also have a quick release version. a pin and plastic washer.
i dont use them though but have them if i wanted to run them at a later time.
pull the pins, remove the washer. store them and zip tie the link up high out of the way.
Poison Spider trail during Easter Jeep Safari 2010.
dropped the right front and the swaybar disconnect smacked the drag link.
snapping it in half. LoL...lesson learned and now they are manually discoed.
i relied on the Rubicon e-disconnect too much.
will prevent you from doing this: SORRY ITS HUGE
below are 2 pics from my Big Bend National Park and Big Bend Ranch State Park runs with members from JKOwners.com
i now disconnect them manually and tie them up high out of the way.
theres no feelig in the world like putting 39" of tire below the rock rails. LoL
as you can see, i now ziptie them to the coil-over mount. they are out of the way and easy to reconnect as needed.
i do not run a rear swaybar. the rear Rock Krawler coil-over system doesnt have enough space for the stock JK swaybar.
i can use a TJ swaybar but it is reversed to the JK swaybar. or i can use the Currie Anti-Rock swaybar. just havent picked 2 up yet.
2007 Unlimited Sahara Steel Blue - I call it "CAIN"
2002 TJ Sport - Sold
"CAIN" '07 Jeep JK 426 HEMI 685 HP & 650 ft lbs
Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
How do I use JKS quicker disconnects? Cleggmeister JK Wrangler Technical Forum 2 09-17-2009 02:11 PM
JKS quicker disconnects djfrost143 TJ Wrangler Technical Forum 11 03-15-2007 07:18 PM
JKS Quicker Disconnects SimonTuffGuy YJ Wrangler Technical Forum 7 08-22-2006 04:37 PM
JKS quicker disconnects hrjaw TJ Wrangler Technical Forum 7 03-28-2006 10:17 AM
JKS Quicker Disconnects Bandit TJ Wrangler Technical Forum 6 08-05-2004 12:37 AM
