Quick question re: RC 2.5" lift kit #656 - JeepForum.com
post #1 of 13 Old 12-28-2012, 05:26 PM Thread Starter
kicker0927
Ordered the 656 kit today to use with stock wheels on a daily driver Rubi Unlimited. I got to reading about the RC 2.5" lift Series 2? Is it really going to be a noticeable difference to get the Series 2 or will I be just fine with the 656? Thanks!
kicker0927 is offline
post #2 of 13 Old 12-28-2012, 07:44 PM
bountyhunter
Without looking it up, I think the series 2 just includes the trackbar relocation bracket and maybe sway bar links? I just walked in the door from installing the same lift you ordered and I do not have any issues where I would need the track bar bracket. Install took 3 hours from the time UPS pulled in the driveway to opening my shop door to test drive. Easy install but had one concern. The front brake line relocation bracket didn't not work very good. The line was in the best position in the stock location, so I left it there. The rear brake line brackets were used though. I'll post before and after pics tomorrow in the daylight.
A big help is to go to O'Riellys and rent their spring compressor. I did my TJ lift without it and was a pain in the butt.
Also Rough Country shorted me the 1/4" x 1" bolt for the brake line brackets. Luckily had a friend who had some in his work truck as I am 20 miles from any store that is open.
bountyhunter is offline
post #3 of 13 Old 12-29-2012, 04:46 PM
thedirtman
thedirtman's Avatar
Not really, they are both crappy cheap lifts. I hear they do have a great warrantee though.
If you learned something new today, you had a good day.
thedirtman is offline
post #4 of 13 Old 12-29-2012, 06:22 PM
bountyhunter
They are the same lift minus a couple parts. Not sure what qualifies a crappy spacer lift, but as far as this type of lift goes this is a good lift. Maybe you don't understand the difference between full lifts and spacers, or did not take the time to look up what the OP was asking about. I will assume the later as its not too difficult to comprehend.
RC uses steel for their spacers as opposed to poly for some other brands. Would I suggest RC's spring/shock lift? No, but for spacers these are the best value for the money.
post #5 of 13 Old 12-29-2012, 06:52 PM
thedirtman
thedirtman's Avatar
I did not say anything about spacers. "crappy spacer lift"? I understand the differences in the two kind of lifts the op is talking about.
The 656 kit is a simple budget boost with relocation brackets for the shocks and brake lines. The series 2 is just longer coils and shocks with no other parts. The rough county shocks tend to ride rough and are prone to leaking and yes I have seen this first hand on several jeeps. Their coils are know to sag bad with age if any weight is added to the jeep like heavier bumpers, armor, or a winch.
Neither of those kits even address extending the sway bar links up front. Nor do they add anything for bump stop extension if the op is indeed looking to install bigger tires and still run the factory flares. No caster correction or sway bar adjustment. I will admit it will be slight but is is there.
Why even include shock or brake line extension brackets if you are not going to lengthen the sway bar links? This is just asking for trouble if taking the jeep off road and full drooping the axle by taking the risk of the sway bar flipping forward and locking up the steering.
RC puts out cheap incomplete lifts and that is why I call them crappy. People only buy their lifts is because of the cheap price point and end up spending quite a bit more to complete the set up. Most would be better off buying a more complete better quality lift in the first place.
post #6 of 13 Old 12-29-2012, 07:00 PM
bountyhunter
You are correct if OP plans to wheel in his machine, the concerns you bring up should be addressed. I installed mine on my wife's JKU and it will never be offroaded, but rather a mall crawler. When wheeling we will use my TJ with the OME lift.
post #7 of 13 Old 12-29-2012, 07:13 PM
thedirtman
thedirtman's Avatar
If just driving around the mall why is a lift required in the first place? To make it handle worse and harder to get in? If it is for bigger tires, 35" tires will fit a jk with just proper back spaced wheels or wheel spacers with some simple bump stop extensions. Now the OME is a quality lift company, it is hard to beat the ride quality you get from their coils and shocks.
post #8 of 13 Old 12-29-2012, 07:14 PM
JTPhoto
JTPhoto's Avatar
To many basic components missing in these RC kits. The TeraFlex BB is more complete then the RC 2.5" lift.
Rear trackbar relocation bracket is a must, extended swaybar links are also important and if you want to flex those 35s extended bumpstops are a must.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is online now
post #9 of 13 Old 12-29-2012, 07:39 PM
bountyhunter
Looks dirtman, it's all about the looks. . Put the Safari Straps top and OFE tube doors with a little lift will be the tits. Not going to go to 35's though, it's still her DD, so probably do 285 75 17s max for the street use.
We have traveled way off topic OP, sorry. If you plan to light wheel it you should be ok. I wouldnt take it deep into the Rockies however.
post #10 of 13 Old 12-29-2012, 08:02 PM Thread Starter
kicker0927
After further research, I will be returning the RC kit. Still not sure what to get into though. Currently looking at Teraflex. I'm thinking I'm going to keep my stock shocks and do the TF coil 2.5 lift kit. Any opinions? And yes, it would be a dd with light wheeling. I live in Ohio....so not a whole lot of heavy wheeling to be had daily here.
post #11 of 13 Old 12-29-2012, 08:08 PM
JTPhoto
JTPhoto's Avatar
If you are gonna keep the stock shocks for now, get the shock extensions.
^^Jeff^^
post #12 of 13 Old 01-29-2013, 08:23 PM
aubreysanchez
I just put the Rough Country 2.5" Spacer lift w/35's. I do not off road either, but it is worth it to make it look a little bigger.
aubreysanchez is offline
post #13 of 13 Old 01-30-2013, 02:45 PM Thread Starter
kicker0927
Is that pic of ur garage or did you park ur rig in your living room?????
